scan to email message
  • tufbnme
    • 493
    Sending from a mpc4503, the email subject is :Message from "host name"
    Is there a way to change the default subject? (message from)
  • sandmanmac
    • 3983
    Re: scan to email message
    Sure.
    WIM / Scanner/ Send settings - at least that's where it is on previous models. I haven't worked on one of these yet.
    Change from default (host name), to manual entry
    • tufbnme
      • 493
      Originally posted by sandmanmac
      Sure.
      That is where the host name is changed, I already know that. What I want to change is the part that says message from.
      • sandmanmac
        • 3983
        Wrong. The Host name is changed under IPV4 settings.
        This is a screen shot from my MP301 where I suggested the setting was, with the "manual entry" changed to MP C4503
          • 37553
          "Subject" button on the bottom of the scanner function screen.
          • tufbnme
            • 493
            It's different on the 4503
              • 37553
              SOP?
              • copier tech
                • 8188
                The "from" email address is the administrators address in the file transfer tab.
                If you change the host name of the printer that will show as the "from" device.
