Ricoh Aficio MP C3000 - Network / Printing Problems
  • Zeerith
    • Mar 2017
    • 17
    Hello Copytech Forum,
    I recently got a Ricoh Aficio C3000 which was connected to a Feiry E3000 Color Controller. The Color Controller is dead , fried on electrical power surge .
    We followed the installation guide of the E3000 and disconneted all parts from the Ricoh Aficio C3000, but still have the Problem that we cant Print via Network or USB directly to the Printer.
    We can access the Printer via Telnet but can't see the Webinterface via IP. We also tried some solutions provided here in the Forum for example : set http up , checked in Service Mode that
    interfaces are enabled etc but still get "404 error" while connecting via webpage. Further the printer dont connect via USB Port ( when we plug in Cable no devices are found )
    Sorry for my poor English .
    with best regards
    Sven from Germany
  • Mark Bbb
    • Jun 2012
    • 1662
    Re: Ricoh Aficio MP C3000 - Network / Printing Problems
    insurance matter if power failure occurred; but it's an old machine...
    Probably new controller needed?
    • Zeerith
      • Mar 2017
      • 17
      We dont want to use the controller anymore , but we would use the Printer directly . But the Connection Ports ( lan / usb ) dont work atm .
      The Printer itself is booting up normally and showing the display , but we cannot access Webinterface of the Aficio c3000 itself . ;(
      In Sp-Mode the 5xxx ( some number i cant remember atm ) for USB + Lan are set to 1 ( enabled )
      and we can access the printer via telnet....
      Maybe Firmware ? the Feiry Button is now also without any function ?
      Greets
      Sven
      • LNorris
        • Sep 2008
        • 645
        ive only set up fiery once, so forgive my ignorance on this, but i believe in the set up sequence there are some sp modes that turn off the nic on the copier so that the second nic works with fiery. i'm sure you will have to double-check those sp modes to renable. dont remember the sp modes tho, been too long ago.
        • Zeldaman
          • Mar 2011
          • 946
          Hi there!
          Try sp 5-193-001 = 0 sp 5-895-001 = 0.Have you removed the little pwb in the controller?
          Greetings...
          • Zeerith
            • Mar 2017
            • 17
            @Zeldaman : In Sp-Mode i dont have sp 5-193-001 = 0 and when i set sp 5-895-001 = 0 the internal Nic is dead and in the printer display the interface tab is gone....
            pwb = you mean the connection card from the e3000 feiry or the raiser card in the printer itself ?
            the connection card of the feiry is removed .
            Thx for all the input ideas ... really want to keep using that printer
            regards
            Sven
            • Zeerith
              • Mar 2017
              • 17
              For more information a Screen i took ...
              Any chance to reset the whole printer to default / factory ? the whole fiery stuff out of the system ?
              Would a complete Firmware Flash Update help ? Not really familar with the Ricoh Aficio Printers...
              • Elmo
                • Feb 2010
                • 541
                5-985-001 nic - 1= enabled
                5-985-002 usb 1= enabled
                with both of them enabled when you reboot and go into service mode do you see printer and scanner sp modes
                also how much memory is installed
                you should have 2 x 512 for stand alone print and scan option
                I Used To Live To Fix Things Now i Fix Things To Live
                • Zeerith
                  • Mar 2017
                  • 17
                  Hmmm that could be the issue ... in the feiry manual was mentioned that you should remove one ram module ... which i couldnt find here anymore to plug back... do i need a special ram module or would any compable 512mb pc2100 work ? Will check sp codes tomorow if those 2 groups are back ...
                  thx for the ideas ! Will report tomorow !
                  • Elmo
                    • Feb 2010
                    • 541
                    you may be ok with memory as long as it is the correct type
                    usually matching pairs but i think you may be ok just adding another 512 pc2100 dimm
                    • gkalman2004
                      • 157
                      Read the e3000 install part and change everything back in reverse order
                      or just remove from the c slot the extension card and set SP5-985-001 to "1"
                      e-5000_3000_manual_final.pdf
                      • Zeerith
                        • Mar 2017
                        • 17
                        Thx , i read the Manual , but havent found the Ram Module . Will have a closer look
                        on that tomorrow . I guess i will find a compatible one . As far as i read a 512 mb pc2100 dimm .
                        Hope it will fix my Problem
                        Thx for all the input , will write tomorrow !
                        cheers
                        Sven
                        • ss12
                          • Jul 2008
                          • 289
                          Sven,after you enter 1 to enable the on board nic press the # key to store it and reboot the machine
                          • Zeerith
                            • Mar 2017
                            • 17
                            Hey Peeps,
                            Sorry for the Late Reaction , but it took a few days before I got a good Ram for the Ricoh Printer.
                            But Still it hasnt changed. But i found out a little more ....
                            Seems like the Firmware for the Printer and Scanner are not in the maschine ..... Also the Loading Programms in Self Diagnosis Report dont show Scanner / Printer.
                            I attached a Picture of the SD-Report.
                            Is there any chance to get these Programms back in the Printer ? Help would be really Appreciated ...
                            with best regards
                            Sven
                              • 37556
                              Originally posted by Zeerith
                              Hey Peeps,
                              with best regards
                              Sven
                              [ATTACH=CONFIG]36323[/ATTACH]
                              If the print/scan SD card is missing, the programs are not going to show in the diagnostic report. There numerous websites that sell used equipment; parts, options and complete machines. Chech the Product Support Guide for the order code of the Printer/Scanner option and Google that.
