Hard Drive Wipe
    • 8081
    Hard Drive Wipe
    I have to arrange the return of a Ricoh MPC-5502 to the leasing company. The customer firsts wants me to first wipe the Hard Drive clean.
    Please provide the procedure to do so.
    Thanks,
  • sandmanmac
    • 3963
    Re: Hard Drive Wipe
    Thanks,
    Remove it and hand it over. Replace it with any off the shelf drive
      • 8081
      Re: Hard Drive Wipe
      Will that not turn the copier into a brick, if it has no operating system? Or does the O/S reside on a board?
      Thanks,
      • zed255
        How'd ya manage that?
        • 1024
        Re: Hard Drive Wipe
        Erase All Data in User Tools > System Settings > Administrator Tools
        OS is in ROM, HDD is just for Address Book, transient data, document server and a select few settings.
        • Zeldaman
          • Mar 2011
          • 946
          • copier tech
            • 8100
            Re: Hard Drive Wipe
            You could can run SP5845-046 in special SP mode, this will delete the address book & reset the admin password back to default.
            Also you can format the HDD using SP5832-001 this will format/erase everything on the hard disk.
            But I agree I also charge the customer for this, get your laptop out, make the process take longer to justify the charge! ;O)
              • 8081
              Re: Hard Drive Wipe
              Thanks to all of the responses!
              • mikedci
                • Jul 2010
                • 227
                Re: Hard Drive Wipe
                +1 Zed255
                The MP C5502's come with DOS which has the secure hdd erase function.
