Ricoh mp c3502 wont detect toner
  • laser801
    • May 2014
    • 151
    [Error Code] Ricoh mp c3502 wont detect toner
    Hey guys....Just upgraded firmware on a mp c3502 and right after it wouldnt detect Blk toner ..Said cant detect... any ideas ???
    Re: Ricoh mp c3502 wont detect toner
    did the firmware upgrade go as planned? any errors?
    what have you done to it since?
    cleaned the sensors?
    re-seated the toner?
    more information is required
    • laser801
      • May 2014
      • 151
      Yes...Cleaned sensors , replaced toner several times....Just talked to someone that said there has been a bad firmware in the field ..supposedly this has happened quite a bit lately... getting new firmware overnighted...let you know...thanks for your response
      • eddy out
        • Oct 2016
        • 359
        did you load the greenline firmware? I have accidentally done that with exactly the same result
        • davel
          • Oct 2011
          • 1108
          greenline firmware??
          • Zeldaman
            • Mar 2011
            • 946
            Hi there!
            What is a "greenline-fw", is this for USA? Only thing i found was the bulletin RD1452024, but nothing with fw. Attention, this year we had 3 or 4 fw-upgrades for this model.
            Greetings...
            • eddy out
              • Oct 2016
              • 359
              the engine fw has an option to choose Greenline (Ricoh "new" refurbished). I asked the same question when this happened to me.
              • Tractorak
                • Oct 2012
                • 3
                We have had the exact thing happen, did the new firmware fix the issue?
                • Athlontini
                  • Jun 2012
                  • 269
                  Looks like what happened is you put in the "greenline" engine firmware, it's a special custom firmware for a line of refurbished machines Ricoh put out. When you search for firmware in RFG eSource, this firmware shows up with all the other ones so it's easy to accidentally download. Go back and check RFG and you should see another engine firmware in there. Load that one and the black toner should recognize again.
