MPc5503 SC990-00
  • tufbnme
    • 493
    MPc5503 SC990-00
    The machine shows this error in the AM, once restarted it works fine all day. The manual indicates to reinstall the software. Is this the firmware (all up to date) or is there some other software?
  • Alex ahir
    • May 2012
    • 125
    Re: MPc5503 SC990-00
    Reflash the firmware again, sometimes it didnt download properly. Which one are you doing package or Romdata.
    • tufbnme
      • 493
      I do the package
      • copier tech
        • 8192
        If you are using the package firmware remember this doesn't update ALL the firmware files, only the main ones. The Official line from Ricoh is to use the module method if you are having issues.
        You may also want to update the Java too.
          • 37556
          With package, only those modules that are not current are replaced. Also, peripheral firmware is not included in the package. As copier tech said, use modules and select all of them.
          Also make certain that there is not anything that requires PM.
          • Cipher
            It's not easy being green
            • May 2006
            • 1309
            Sounds like an energy saver / low power mode recovery issue.
            So many problems identified and fixed via firmware these days.
            Code:
            SC990 When machine is powered on.
            Java VM install version 11.13.01 (or newer).
            Energy saver mode
            A Java VM internal process changes the configured sleep timing.
            Java VM install version 11.10.02 (or newer).
            SC990 After the machine recovers from Energy Saver Mode
            GW-FCU install version 09.00.00 (or newer).
            Energy saver mode, no recovery.
            System/Copy firmware install version 1.11 (or newer).
            PowerSaving Sys firmware install version F.18 (or newer).
            • tjvincent
              • 280
              On the newer machines with version 2 of smart panel package updates the smart panel OS so it's also just as important to do package first then module
              • tufbnme
                • 493
                Thanks for all the information. I was not aware that the package FW does not update ALL and I have to also update individual modules.
                Now I have to remember all the machines that didn't get the modules updated.
                  • 37556
                  It does "Update" main frame modules that are not current. It is not able to detect current modules that need to be redone.
                  • Zeldaman
                    • Mar 2011
                    • 946
                    • Polarbear
                      • Feb 2012
                      • 1070
                      [ATTACH=CONFIG]36507[/ATTACH]
                      Check sp7404 - it will show the file that is causing the code. It lists the last 10 entries.
                      Press the GREEN button!!
                      • tufbnme
                        • 493
                        Re: MPc5503 SC990-00 991
                        Here are the files causing the issue, the problem is I am not sure where to go to resolve the problem knowing this file information.
                          • 37556
                          [ATTACH=CONFIG]36744[/ATTACH][ATTACH=CONFIG]36745[/ATTACH]
                          SDK is JAVA. Try turning JAVA off in User Tools. If that clears the problem, update JAVA.
                          • tufbnme
                            • 493
                            Is it cool to just leave it off?
                            • aktasson
                              • Feb 2017
                              • 201
                              I found that here as temporary step -> SP2-250-001 to "0". As permanent durable solution -> newest package fw and after that carry out the printer, pcl, powersys and java update.
                              after that the
                              2017-06-01 18_38_18-Microsoft Word - RD147000k.doc - RD147000k.pdf.jpg2017-06-01 18_37_57-Microsoft Word - RD147000k.doc - RD147000k.pdf.jpg
