RICOH MP 2852 (JAM 052)
  • omorales
    • Mar 2015
    • 86
    Hi friends, I would like to know if anyone has had this problem.
    Jam 052, just happens on tray two. The registration clutch stays, and stops spinning.
    From the tray one all there is no problem the registration clutch will be nine normally.
  • copyaction
    • Oct 2007
    • 991
    Re: RICOH MP 2852 (JAM 052)
    Where does the paper stop?
      • 37489
      J 52 is a trail edge jam from tray 2. Check that paper size is set correctly.
      • omorales
        • Mar 2015
        • 86
        Thanks for the answers.
        Tray 2 is set correctly.
        The paper jam is over, passing the transfer roller.
        • copier tech
          • 8144
          From SP mode do an input check on all the relevant sensors, especially those relating to tray 2
          Does it feed OK from tray 4?
          • COPIERMAN
            • Jun 2009
            • 559
            since you say tray is set properly then could be transfer roller or paper feed clutch is not disengaging.
            • omorales
              • Mar 2015
              • 86
              Hello friends .
              I have changed registry cloucht and solved the problem.
