Scan to SMB Only Working with SMB 1 Enabled
  • Gunnett
    • Jun 2025
    We have 16 Ricoh MP 501's and a Ricoh C6004. I believe these units support SMB 2.0 and possibly higher. They are connected to the local domain and are trying to Scan to the Local Windows Server 2012 R2. They can scan fine to the Windows Server as long as SMB 1.0 is enabled but we don't want that enabled for security reasons. I have telnetted into the Ricoh units and tried switching the SMB port from 139 to 445 and tried experimenting with the different smb client auth levels. The only thing that seems to allow scan to folder to work is enabling SMB 1.0 on the Windows Server. The Network Support firmware on the C6004 is 15.61.
  • slot
    • 341
    Re: Scan to SMB Only Working with SMB 1 Enabled
    we have had the same question today from a school whom is being advise to turn off smb v1 we I would be intrested in the answer as I think this is going to be a big problem due to the weekend cyber probs
      • 37319
      1. Domain name on the MFP MUST be exactly correct in interface settings. If it is not, then DNS requests from the MFP will be ignored. I had a school system this last fall where some MFP were scanning some were not. I found that the ones that were not had .org at the end of the domain not .com. I had gotten the .org from their email addresses. It was their Google Apps domain not the local domain.
      2. First DNS entry must be the local DNS server, usually the Domain server.
      3. Scan to folder must be by computer name. Scan to IP address has been blocked since a Server update last summer.
      • HDSB
        Field Tech
        • Feb 2013
        • 64
        We have a customer who did the same.
        I called Ricoh tech support (straight to second line) who advised Ricoh only work on v1.. nothing can be done.
        • sturmtrooper
          Copier Combobulator
          • May 2016
          • 587
          You may be better off having an FTP share setup and scanning to that.
          • TonerMunkeh
            Professional Moron
            • 3865
            I've run into this myself. I find it astounding that a global manufacturer, especially knowing what trouble Windows 8 and Server 2012 caused, haven't brought something out to sort this. It's only a matter of time before the shit properly hits the fan.
            Hit it.
              • 37319
              I don't know who at Ricoh you have been talking to but at least in North America that is not true. Ricoh MFPs have supported SMB v2 since first firmware updates following Microsoft's introduction of Windows Vista. Windows 8 forced all MFP manufacturers to rewrite firmware to be able to use SMB v3.
              To confirm, ive seen an internal Ricoh email:
              • Ricoh MFDs support no version of SMB
              • GW architecture uses Samba which is fully compatible with SMBv1 only at the time of writing
              • Ricoh Japan are monitoring the situation
              You might want to check the origin date on that internal email. Only those Ricoh models that do not have firmware update by SD card. Those model that have SD card firmware update compatibility are based on GW+ architecture.
              • HDSB
                Field Tech
                • Feb 2013
                • 64
                Ricoh tech support level 2 UK
                and
                The email is dated today, the email clearly states GW architecture is based on UNIX (Samba) not Windows (SMB)
                if anyone can prove otherwise then that would be great cause we have a customer wanting to remove 50 devices!
                  • 37319
                  and
                  All current models are GW+ architecture. Yes they are UNIX based but current Samba can emulate SMB v3 with proper firmware.
                  • HDSB
                    Field Tech
                    • Feb 2013
                    • 64
                    Ricoh seem to think otherwise then! We have an mpc 5054 included in the devices not scanning, all brand new Ricohs anyway i think.
                    Can you give specifics regarding proper firmware? these devices are on the latest firmware.
                      • 37319
                      All new Ricoh and all production firmware since 2013 have supported SMB v3. If you are having problems it might have to do with the OS you are scanning to. I suggest that you search through the Connectivity forum as scanning is thoroughly covered there.
                        • 37319
                        Attached is the firmware history for the MP C3002/MP C3502. See items corrected by Network Support Firmware v 11.96. This is an example of when Ricoh USA updated firmware in order to scan to Windows 8/Server 2012(SMB v3).MP CXX03 SMB v3.
                        • Mr Spock
                          Vulcan Inventor of Death
                          • Aug 2006
                          • 2064
                          If the pc or server has a static IP then try this and see if it works, I was told this only works when scanning via IP.
                          If the computer(or server) has an ip of 192.168.1.10 and the path is public\scans then put the path as follows:
                          \\192.168.1.10:445\public\scans
                          Also make sure that the pc/server is on a Private/work network in the Network and Sharing center.
                          • tonnerboy
                            • May 2011
                            • 212
                            Just out of curiosity, can you show documentation from Ricoh to confirm what you are saying? I work for a massive UK dealer and we are getting insider information straight from the horses mouth that contradicts your information.
                            Personally i am not having problems - refer to the original post and comments. Scanning works when SMB is enabled and stops when disabled.
                            I have the same information. All Ricoh devices only support v1.
                            I have been contacted by several costumers with this problem ... and for now there is no solution!
                            • Cipher
                              It's not easy being green
                              • May 2006
                              • 1309
