MP 1100
  • Domingos
    MP 1100
    Can you help me, is there a way to downgraded frimware on a MP1100. as after installing the new frimware we have extra problems
  • Voltage
    • 282
    Not that i know of. Maybe i can help with some of the problems?
    • Domingos
      Nice to see a reply from RSA, as an expratiot, but the problem is that when we up-dated the frimware, we now have a stack of problems with SC990 and Sc670 codes
      • RebelPhoenix
        • 138
        Dear Domingos.
        When will you want to a firmware update this copier it's time you must update is first engine software. When will you machine show the " Update sussecfly. " It's time you must click the off after on after you must the other firmwares update.
        Do you have this machine last firmware ? If You don't have please says it I upload the a sharing sites for you.
        • cobiray
          Passing Duplication Xpert
          • Mar 2008
          • 1199
          Also make sure you update ALL the firmware and not just the Engine and System. I've had some of the most recent generations exhibit strange symptoms (codes, jamming, unable to enter tech mode) when not updating all the firmware.
          • Shadow1
            • Sep 2008
            • 1642
            Ricoh usually keeps a current and previous version on the tsc web site - but as was mentioned, make sure you update EVERYTHING starting with system and engine. For those particular SC codes you might want to try formatting and / or replacing the HDD's
            73 DE W5SSJ
            • RebelPhoenix
              • 138
              Hi Dear Shadow.
              I don't understand. And I'm worry. We must the update first one System with engine firmware or first one only engine firmware after update the other firmware ?
              • Shadow1
                • Sep 2008
                • 1642
                73 DE W5SSJ
                • FRIDGEMAGNET
                  • Aug 2007
                  • 377
                  Originally posted by Shadow1
                  Not sure why - I assume there may be some conflict between versions of firmware - but that is the procedure outlined in TSB 046 for the machine:
                  The reason is that with the new firmware you are upgrading the machine from a MP1100 to the Pro110 (Katana C1 to Katana C1.5).
                  If you upgrade the system firmware first, the machines thinks it is a C1.5 and sees a C1 engine firmware and locks itself out.
                  This means that ALL the other firmware needs to be updated to these levels:
                  If all these are not done then you can get some very wierd problems - Please Wait, Unable to access SP mode, parts of the screen missing and SC codes.
                  • Domingos
                    Much appreciated your input, it helped in solving the situation.
