Ricoh MP 2000L SMB scanning
  • Pulsara
    Technical Manager
    • Aug 2015
    • 27
    Hi friends, One of my customer using windows 7 with Ricoh MP 2000L copier for SMB scanning. Recently they updated their computer security to defend from Ransomeware. Now they cannot do scan to folder. Also asked me to upgrade copier SMB version 2 or above. I have done firmware update had with me. but problem not solved. I don't know the way to check which version the copier currently using. Can anybody help me to solve this? Thanks.
  • TonerMunkeh
    Professional Moron
    • 3865
    Re: Ricoh MP 2000L SMB scanning
    Print SP5990-005, diagnostic sheet. All firmware is listed there.
    Hit it.
    • tonnerboy
      • May 2011
      • 212
      All Ricoh devices only support samba v1...
      (I think this already answer to your problem...)
      So, if they desabled the samba v1 they can not use Scan-to-folder
        • 37378
        NIB firmware needs to be B8675526K, v6.19.
        • Pulsara
          Technical Manager
          • Aug 2015
          • 27
          Thanks for the advice. I already updated firmware B8675526K, v6.19 but copier still respond only to SMB 1. Is there any update issued after that.
          • TonerMunkeh
            Professional Moron
            • 3865
            Check this thread out:
            http://www.copytechnet.com/forums/co...wanna-cry.html
            Hit it.
            • Mark Bbb
              • Jun 2012
              • 1662
              are passwords still the same and correct?
              • Pulsara
                Technical Manager
                • Aug 2015
                • 27
                After firmware update, I tried scanning with SMB 1 enabled. Scanner works normally. When SMB 1 disabled, it stopped working.I mean the device still use SMB 1 for communicating. Done these things with Windows 10. Thanks.
                • Mark Bbb
                  • Jun 2012
                  • 1662
                  configure it as scan to e-mail (smtp).
                  does it work fine?
