office 365 scanning malfunction: document sent for 100% but not receveid in mailbox
  • Mark Bbb
    • Jun 2012
    • 1662
    Hello,
    mpc2003.
    smtp server connection test = ok.
    Scanning is going from 99% to 100% and is logged in the journal as being send as "completed"
    But... client won't receive the scan in the mailbox.
    SMTP Server Name: smtp.office365.com
    SMTP Port No.: 587
    SMTP Authentication: On
    SMTP Auth. Email Address: email@mydomain.com
    SMTP Auth. User Name: email@mydomain.com
    SMTP Auth. Password: ******* (It's the correct password)
    SMTP Auth Encryption: Auto-Select
    Anyone can help? Thanks in advance.
  • acfife
    • May 2012
    • 63
    Re: office 365 scanning malfunction: document sent for 100% but not receveid in mailb
    Have you tried setting encryption on to TLS or STARTTLS rather than auto?
    • TonerMunkeh
      Professional Moron
      • 3865
      Try using the customer's MX record as the SMTP server. Port 25 with no authentication. Administrator's email address can be anything with ending with the same domain, i.e. MPC5503@yourcompany.com
      Hit it.
      • Mark Bbb
        • Jun 2012
        • 1662
        @acfife: yes, we did.
        • Mark Bbb
          • Jun 2012
          • 1662
          https://mxtoolbox.com/
          @TonerMunkeh: we will try this asap. We will keep you informed.
            • 37533
            Have you tried checking the junk mail or bulk mail?
            • acfife
              • May 2012
              • 63
              what about setting up with a gmail account or smtp2go, something like that if it sends ok with that it has to be down to office365 setup.
              • Mark Bbb
                • Jun 2012
                • 1662
                @Slimslob: yes, we did, wasn't received there either.
                • StephenB
                  • Aug 2015
                  • 244
                  Hello,
                  mpc2003.
                  SMTP Port No.: 587
                  It appears your outgoing ( smtp ) server is functioning (goes to 100%), however their incomming email is not being received. That has to do with their (incomming)email domain server.
                  I also verify the username and password by logging onto their account from a web interface.
                  I always test an email to my phone gmail for testing purposes.
                  And lastly, as previously posted, try a SMTP2GO, free account 5 min set up
                  • Mark Bbb
                    • Jun 2012
                    • 1662
                    My weekend starts here and now, good weekend to you to.
                    Hope to inform you more on Monday in the afternoon...
                      • 37533
                      You may need to setup using option 2 or 3 in the following. https://support.office.com/en-us/art...8-c805d654b4c4
                      • ZOOTECH
                        Senior member of CRS
                        • 3375
                        Hello,
                        mpc2003.
                        SMTP Port No.: 587
                        Not sure about your brand, but with Sharp, the email address needs brackets (< >) at the beginning and end.
                        • pebkac
                          • Oct 2014
                          • 36
                          It's not clear from your description if the recipient is inside our outside your client's organization. If they're inside, the Office 365 Exchange admin center has a mail trace option that's useful for troubleshooting delivery problems. Exchange > mail flow > message trace.
                          And don't forget about the Clutter folder.
                          • guitar9199
                            • Sep 2016
                            • 1100
                            I ran into a similar issue using a Gmail account on a Ricoh MP C3503. In the File Transfer settings, I turned OFF the "Divide into separate emails over XXMeg" switch, and it resolved my issue. Apparently Gmail doesn't like to divide emails?
                            • Mark Bbb
                              • Jun 2012
                              • 1662
                              Thank you all for your inspiring answers.
                              Have anyone in fact successfully activated O365 at all, on a Ricoh device?
                              I know it's an other answer, but I guess it's relevant for the solution of this tread because
                              it could very much be that Ricoh's fail to activate O365!
                              So???
