Ricoh C2550 Savin C9025 paper tray noise
  • ChrisG
    • Oct 2013
    • 181
    Good morning,
    Almost certain there was a tech update for noise from the sep pad and feed tire from the trays for this series but no longer have access to the pub and/or updated part numbers. Can someone help out with this?
    Chris
    TJL Copy
    • 37383
    Re: Ricoh C2550 Savin C9025 paper tray noise
    Problem is the friction pads vibrating. Ricoh changed the pads to add a film of lubricant to those areas that contacted the plastic of the tray.
    • ChrisG
      • Oct 2013
      • 181
      I was pretty certain that that was the case. Wasn't sure if they changed the spring underneath the pad as well.
      Do you have the updated part numbers by chance?
      Chris
      TJL Copy
        • 37383
        D1052722
        For more information see Service Bulletin 006 for the MP C2551.
        • ChrisG
          • Oct 2013
          • 181
          D1052722
          Much appreciated. Thankyou
