Don't know ricoh that well but hate to turn away new customers that I may be able to upgrade to Konica Minolta, which I mostly deal in.
Went to check it out and customer's complaint was a smudge & wrinkling. Since this was a free estimate I didn't want to take too much apart. 200k clicks.
All I did was slide fuser to the right like the end user would to remove a jam (machine was on). Inspected rollers and they look good. Slid fuser back in closed side door and machine threw SC 554-00. Reseated fuser unit several times and tried resetting with SP 5-810, after executing turned mach off and back on and still same code. Am I doing something wrong when trying to reset this code?
I found some stuff on this forum and on the web about needing to replace the fuser, Eprom, & BICU pwb to clear this code. Is it true you need to replace all this for a bad fuser? Fuser alone cost over $1000 !!!
Sucks that machine was working and when I left machine was not working. Add this to my list of why I hate Ricoh!
Any help appreciated
Thanks in advance
Thanks in advance
