Scan to folder (SMB) win 10
  • Anjaskaseto
    • Nov 2014
    • 55
    How to set scan to folder (SMB) on MP 3351 in windows 10
    • 8103
    Re: Scan to folder (SMB) win 10
    Same way you do on all Ricoh's!
    If it is failing to connect you will need the latest network firmware to scan to windows 8.1 & later.
      • 36848
      There are a number of threads recently throughout CTN concerning the recent problem with scan to SMB on all Windows versions. since the patch released by Microsoft following the ransom virus outbreak. Do a little searching on Scan to SMB v1.
      • paulg
        • Jun 2007
        • 278
        Check the Network Admin has not switched off/blocked SMB 1on the network.
