Wrong model
  • islam90kh
    • May 2017
    • 7
    Wrong model
    Ricoh AFICIO SPC232SF get error wrong model after change in special sp mode
    need help please thanks
  • sandmanmac
    • 3981
    Re: Wrong model
    Change What?
    This didn't just happen by itself. What happened, and what did you do?
    • islam90kh
      • May 2017
      • 7
      Re: Wrong model
      Originally posted by sandmanmac
      Change What?
      I was try fix fuse and with wrong i changed model
      can you help me to fix it please thanks
      • sandmanmac
        • 3981
        Re: Wrong model
        Sounds like you made a real mess of things, and NO I can't help you.
        Obviously, I can see your post, and I'll help if, who, and when I so choose, so sending me a PM to ask was unnecessary!
        • islam90kh
          • May 2017
          • 7
          Re: Wrong model
          Ohh sorry man ,, i am new here i am dont know rules and this printer for my work and this will make for me big problem
          • copier tech
            • 8172
            Re: Wrong model
            Start from the beginning,
            (1) What was the initial fault/problem with the machine?
            (2) What EXACTLY did you do in special SP mode?
            (3) What have you tried since.?
              • 37532
              Re: Wrong model
              If you can no longer get into SP mode to change back what ever you have changed, you are going to have to replace at least the EEPROM on the Engine board and possibly the Engine board. Worse case scenario, you will need to replace the EEPROM, engine board and controller board. Looks like trying to fix the original problem yourself is going to cost you a lot more that calling a qualified tech would have.
              • COPIERMAN
                • Jun 2009
                • 559
                Re: Wrong model
                looks like you change serial number. You can try to go back in special mode and enter # of copier
                4.1 SERVICE MENU
                4.1.1 OVERVIEW
                This model has several service menus. Each service menu has several adjustment items.
                This section explains how to enter each service menu and what you can do in each service
                menu.
                Each menu is classified into two "Modes" depending on how you enter the service menus.
                􀂃 "Menu Mode" can be executed by depressing the following key sequence while in ready
                condition:
                Clear/Stop, 1, 0, 7 and Color Start. (Press and hold each key till a beep is heard.)
                􀂃 "Special Mode" is needed to input the serial number after the Engine Board EEPROM
                has been replaced. Please contact your Technical Service Manager for details.
                Each menu is classified as follows:
                Menu Mode Function
                Maintenance Mode Menu This is a menu for maintenance and service.
                Special Mode This mode is used to input the serial number.
                Fax Service Test Menu This is a menu for checking the fax mode
