Is it normal for ricoh mp65/7500 every 250K Waste toner bottle full ?
  • hsh6049
    • Jul 2012
    • 64
    hey guys can idea wht's going on my ricoh mp65/7500 every 250k waste toner bottle full
    • 37107
    Re: Is it normal for ricoh mp65/7500 every 250K Waste toner bottle full ?
    Normal PM cycle is 300K so 250K is not far off. I would say that either you are running slightly over toned or you are using third party supplies. Another possibility is machine is not getting the proper usage. If usage is too little, amount of toner dumped to the waste during auto process control becomes a larger percentage of total toner waste.
    • hsh6049
      • Jul 2012
      • 64
      Normal PM cycle is 300K so 250K is not far off ( do u meant Even use original toner every 300k the waste toner will full?) of course i am using compatible toner but i had two units mp6500 one every 250k full but he other running 1 million
      just only a few in waste toner bottle
      • andy227
        • Jan 2013
        • 219
        Compatible toners do not work well with this machine. They dump toner everywhere, they overtone, they undertone. False economy. Also check your re-cyclying/classification unit on the dev unit. They are notorious for the mylar paddles coming off and not working ok. When I have the dev unit out for whatever other reason, I routinely check the re-cycle unit and find that I have to glue back the mylar paddles half the time, assuming I can find them.
        • aktasson
          • Feb 2017
          • 201
          As slimslob already said, usage could be the problem. Check the smc all list for jobs/PGS (SP 8-071).
            • 37107
            The experience tech empties the waste toner as part of a regular PM. Saves having to drive an hour to the customer when it fills up a week or two later. We also tend to check them on every service call for the same reason. Let see 1M divided by 3 (a few) is 333K. Well with the the expected variance.
            • Tonerbomb
              AutoMajical Resolutionist
              • Feb 2005
              • 2589
              [ATTACH=CONFIG]36785[/ATTACH]
              Also check the pages by fill rate, too many pages with fill rate below 5% will cause excess waste and the machine will run dirty.
              After market toner SUCKS!!!!!!!!!!!!1
              Mystic Crystal Revelations
              • Lagonda
                • Aug 2008
                • 1649
                How old is your developer? Toner won't bind to developer thats worn out or contaminated with paper dust.
                • hsh6049
                  • Jul 2012
                  • 64
                  How old is your developer? Toner won't bind to developer thats worn out or contaminated with paper dusrunning
                  running more than half million, but i got one unit mp 6500 developer running 700,000.00 ...the waster toner bottle only containt a liittle bit waste toner thats why i dont understand
                  never change any setting before, same toner same type of developer but the other unit easily get full
                  • Polarbear
                    • Feb 2012
                    • 1070
                    AFAIK these machines have a toner recycle/waste system. Is it possible that through settings it was forced not to open the waste solinoid until much higher readings than normal?
                    That would explain why the waste was almost empty.
                    Press the GREEN button!!
                    • davel
                      • Oct 2011
                      • 1090
                      No waste solenoid in any of this range of machines over many years.
                      • MIKON
                        • Jul 2015
                        • 186
                        Not normal
                        Dump developer
                        Clean every bit off dev
                        Cylinder.
                        Turrn knob and vac until there's nothing left.
