mp 6500 lines
  • vargue
    • Oct 2011
    • 404
    [Misc] mp 6500 lines
    hi fellas yesterday customer call me that there is streaks in page it's look like parecode lines i went there it's no error code revealed it's happend every 10 or 5 did some one encounter in this i cleaned controller box but no avail
  • vargue
    • Oct 2011
    • 404
    Re: mp 6500 lines
    no one see that befor it's miracle
    • Mark Bbb
      • Jun 2012
      • 1662
      Re: mp 6500 lines
      "i cleaned controller box" you write.
      I presume you mean a memory clear or so?
      I also can not see a problem on the example you have posted.
      So????
      • vargue
        • Oct 2011
        • 404
        Re: mp 6500 lines
        hi i mean clean dimm and formatt hdd and problem is that lines that the same shape in paper thread.wired lines
        • Polarbear
          • Feb 2012
          • 1070
          Re: mp 6500 lines
          I know when the IPU or laser unit fail, they can cause random thickness and spaced lines.
          Press the GREEN button!!
          • davel
            • Oct 2011
            • 1109
            Re: mp 6500 lines
            Please post samples, print/copy, internal print.
            • Brianneoe
              • May 2015
              • 322
              Re: mp 6500 lines
              Back up your address book and re-format the HD
              • Mark Bbb
                • Jun 2012
                • 1662
                Re: mp 6500 lines
                he already did that, you can read that in his next posts.
