Scan to email with Office 365 (MP C2551)
  • sharpmind
    • Sep 2009
    • 478
    Guys, have you tried to setup any Ricoh printers to send email using Office 365? Any ideas will be appreciated. Thanks!
    • 37561
    Re: Scan to email with Office 365 (MP C2551)
    Microsoft support document. I do not believe that the MP C2551 supports TLS/StartTLS so you will have to use Option 2 or Option 3.
      • 8195
      With these old models I use a gmail account, works fine with no issue & can send email to any address.
        • 37561
        MP C2551/MP C2051 were the first color models to support SSL over SMTP. It is however limited to 2000 messages a day. For older models, you had to use one of Google's non SSL options.
        Set up a device or app to send email through Google Workspace Who this article is for This article is for Google Workspace administrators who want to send email from devices or apps in their
        • sharpmind
          • Sep 2009
          • 478
          Here are settings I used....
          1. SMTP SERVER:smtp.gmail.com
          PORT:465
          DNS: 8.8.4.4
          Username:gmail account
          Password: gmail account password
          CONNECTION TEST: SUCCESSFUL
          SCANNING TEST: FAIL
          2. STMP SERVER:mail.messaging.microsoft.com
          PORT:25
          NO AUTHENTICATION
          CONNECTION TEST:SUCCESSFUL
          SCANNING TEST: FAIL
          3.SMTP SERVER:smtp.office365.com
          PORT:587
          SCANNING TEST:FAIL
          The client has called up the technical support from Office365 from United States but he did not solve the problem.
          • ZOOTECH
            Senior member of CRS
            • 3375
            Originally posted by sharpmind
            I also use smtp.gmail.com as smtp server. When I do the connection test it is successful but when I try to scan it fails. Any ideas why it fails?
            With Sharp's, the reply email must have < before and > after. This might not be the case any longer.
              • 37561
              PORT:465
              DNS: 8.8.4.4
              SCANNING TEST: FAIL
              Requires that you first install a certificate on the MP C2551 to enable SSL. How do I setup SMTP over SSL on a Ricoh Family group device.pdf
              PORT:25
              NO AUTHENTICATION
              SCANNING TEST: FAIL
              That is not the correct SMTP server for relay. Usually has to be configured specific to your Office 365 domain. Should be similar to yourcontosodomain-com.mail.protection.outlook.com. Will need to be setup either by Microsoft or by the client's IT. Must specify to Microsoft that they need to create a relay server service.
              PORT:587
              SCANNING TEST:FAIL
              Requires that the MFP supports TLS/StartTLS. MP C2551 does not.
                • 8195
                I have used the first option posted above without the need to install the SSL certificate, this maybe due to the firmware we have available in The UK.
                Also I use a different DNS as below.
                PORT:465
                DNS: 8.8.8.8
                2nd: 8.8.8.4
                Admin Address: Any email works ok
                SCANNING TEST: PASS
                • rthonpm
                  • Aug 2007
                  • 2859
                  For Office 365, just setup Stunnel on a server or always on PC and use that as your SMTP server. You just need to setup Stunnel with the correct smtp server name and port for O365 (smtp.office365.com:587) and then is will route the email from the MFP to itself and then to the O365 servers. You'll need to make sure that the copier has valid credentials for the email address since those will be pushed along with the message. I had to do this for my own office with my MP171 and it worked right away.
                  • aktasson
                    • Feb 2017
                    • 201
                    The Diana range 2050/2550 does not support ssl/tsl (port 465/587) for smtp. But 2051/2551 with latest fw does it. Most popular freemail provider almost using ssl.
                    Best solution is to install a local mail server working on port 25. Emails can then be forwarded automatically from the local mail server to the desired e-mail address.
                    2017-06-14 18_56_29-Microsoft Word - Service Information1.doc - Techtip1.pdf.jpg
                    Will not work over web image monitor, it can be configured over the machine panel!
                      • 37561
                      [ATTACH=CONFIG]36876[/ATTACH]
                      Will not work over web image monitor, it can only be configured over the machine panel!
                      For older models that do not support SMTP over SSL, I have had no problems using Google's Restricted Gmail SMTP server, aspmx.l.google.com. The restriction is that you can only send to another Gmail or G Suite user.
                      • aktasson
                        • Feb 2017
                        • 201
                        First try with the mp c2551 is 1: port 465, if does not work then 2: port 587.
                        Sets in advance...
                        1. machine settings correct (date/time, sntp, etc., tcp/ip), 2. mpc comes into the inet, 2. mail server address correct (and reachable), 3. username (e-mail) and password correct
                        • aktasson
                          • Feb 2017
                          • 201
                          Yes, that should work. A good emergency solution to send scans to your own e-mail etc. But here in my country it does not work. I did not get it running with older devices. I have a MP 171 in my home, I like to test if you give me settings for the mfp.
                          • Mark Bbb
                            • Jun 2012
                            • 1662
                            http://www.copytechnet.com/forums/ri...d-mailbox.html
