Toner ricoh aficio 1027 can use on plan printer mpw2400
  • Matoku
    • 173
    [Misc] Toner ricoh aficio 1027 can use on plan printer mpw2400
    Hi Friends
    Did you know that toner for Aficio 1022/1027 (katun refill toner) you can use for plan Printer MPW2400?
    May be you don't believe me right. This is true. I am using it for 1 year already and the machine works well
    until today.
    However we have to replace the developer (type 30) together with the toner 1027.
  • Tonerbomb
    AutoMajical Resolutionist
    • Feb 2005
    • 2589
    Re: Toner ricoh aficio 1027 can use on plan printer mpw2400
    This is a bad idea that will cause you many problems. After market toner SUCKS!!!!!!!!!!!!
    Mystic Crystal Revelations
