MP C6501 SC408
  • Pokerking1993
    • Jan 2017
    • 17
    MP C6501 SC408
    Hello everyone,
    We have a few 6501's that continue to have SC408 errors and there is hardly any info on repairing this issue. What I have done with one of the copiers is swap the drums with a known good set, which held off the errors for a few days but came back. Any help would be great!
    I am beyond happy that my company is starting to phase out these piles...
    • 37502
    Re: MP C6501 SC408
    From Goose's Guide
    D081/D082 SC 408 Id sensor error Cyan - ID sensor defective
    D081/D082 SC 408 Id sensor error Cyan - clean ID sensor array
    From the service manual Toner Shield glass dirty, Development Unit defective, Image transfer unit defective.
    • Pokerking1993
      • Jan 2017
      • 17
      Re: MP C6501 SC408
      Where is the toner glass located? I don't recall seeing any glass on/near the ITB unit nor on a dev unit.
      • davel
        • Oct 2011
        • 1105
        Re: MP C6501 SC408
        Look above PCDU
          • 37502
          Re: MP C6501 SC408
          Open the front door, remove the toner supply unit and check the toner shield glass for dirt. Each PCDU has a separate shield glass. They should have a Mylar pull out tab accessible through a slot in the face plate directly above each drum.
          • HitMan
            • Aug 2015
            • 170
            Clean the itb ID sensors with alcohol
            • davel
              • Oct 2011
              • 1105
              Re: MP C6501 SC408
              Use a damp cloth, not alcohol it can affect the sensor.
              • HitMan
                • Aug 2015
                • 170
                Alcohols the only thing that worked for me
                • sturmtrooper
                  Copier Combobulator
                  • May 2016
                  • 587
                  Re: MP C6501 SC408
                  Alcohol can damage plastic. If you affect the light transmission properties of the plastic covering the sensor eye you will change the sensor output. If you have something stuck on there that water and a cleaning cloth wont remove you should probably just replace the sensor.
