MPC3500 and DF3010 Jamming -53
  • aktasson
    • Feb 2017
    • 201
    [Jamming] MPC3500 and DF3010 Jamming -53
    Hi, folks!
    We have on the field a mpc3500 with df problems.20170629005311884.pdf On smc list -53 was logged 29 times.
    The reverse roller, feed belt and roller pickup have been replaced on last visit round about 3 month.
    All the sensors with the black hole are well cleaned. Under the white df mat (preasure plate) i disassembled the guide and I cleaned all the rollers and the sensor.
    The strange thing is that, when i do testscans over sp adf free run or scanning to the document server etc. the df stops sporadically in the middle of scanning. The rest of the documents remains on df, two pages leaves were left behind in the paper path and the machine does not display any error, huh !?!?!
    Does anyone can help?
  • NeoMatrix
    Senior Tech.
    • 3513
    Re: MPC3500 and DF3010 Jamming -53
    There are quite a few old posts with the available info.
    The below should get you going.
    search site : www.copytechnet.com 3500 ADF jamb
    wwww.copytechnet.com/forums/ricoh-savin-gestetner-lanier/94998-ricoh-mpc3500-adf-jamming-j005.html
    http://www.copytechnet.com/forums/ri...ming-j005.html
    HTH
      • 37560
      Separation roller or torque limiter for separation roller.
      • aktasson
        • Feb 2017
        • 201
        Ok the torque limiter is in our on stock i will start first with it.
        Has anyone experince with the modification parts to solve 53 jamming? Was recommended by product support RICOH Germany.
        GUIDE:REVERSE:OPEN AND CLOSE B8022228,, TORQUE LIMITER MECHANICAL CLUTCH:SE B8022255,, GUIDE:EXIT:UPPER:SUB-ASS'Y B8023655,, TIMING PULLEY:T33-T24 B8023235,, TIMING BELT:40S3M186 B8021774,, SEAL - 0.7X13X20 A4221063
        • NeoMatrix
          Senior Tech.
          • 3513
          The following old post are for the mpc4500.
          I have replaced similar to these on mpc3500.
          wwww.copytechnet.com/forums/ricoh-savin-gestetner-lanier/68866-mpc4500-jam-56-registration-off-adf.html#post312580
          http://www.copytechnet.com/forums/ri...tml#post312580
          HTH
          • aktasson
            • Feb 2017
            • 201
            The curious thing is that the df stops scanning in the middle and does not cause any error. 2 pages stay in the paper path :/
            The copier button changes to green... hmmm crazy. That would be under normal condition a df paper jam.
            • Gary Bowen
              Bowdog
              • Mar 2008
              • 250
              You may want to check out this Service Bulletin. What happens is the gear on the end of the shaft that drives the Reverse Roller slips on the shaft (it is only press fitted on). You will get intermittent Jam Code 53's.
              • aktasson
                • Feb 2017
                • 201
                Thanks for the info. That is the parts I wrote above. But very good to see the Bulletin and the infos for the problem. I ordered all the parts. Let's hope for the best.
