Newer ricohs have admin log-in how do i override?
  • scor-p
    • Aug 2025
    I need some help.the newer ricohs like the 3045 and 2060 have user id settings.however when trying to change settings it says i do not have permission to change the settings.there is a log-in page on the user tools page which has two required passwords the upper asks for the user n the lower for a password.is there a way around this problem?
  • iMind
    Vacuum Cleaning Expert
    • Mar 2008
    • 1116
    just login with username "admin" no password required
    • pspahr
      Toner Schlep
      • May 2008
      • 227
      That's assuming no one changed anything. You may try Supervisor with no password and that should allow you to reset the Admin password. Caution, though, to make sure the customer is ok with you doing that.
      VectorLinux---Check it out!
      • iMind
        • Mar 2008
        • 1116
        YEP, sorry
        • cobiray
          Passing Duplication Xpert
          • Mar 2008
          • 1199
          And make sure your copier support company knows you changed it!
          • scor-p
            thanks
            HI,
            thanks for the help.the admin did not work but will try the Supervisior one.
