Ricoh MP 2000 Stuck with error code
  • raveendrala
    • Oct 2016
    • 80
    [Dead] Ricoh MP 2000 Stuck with error code
    Hello,
    I got Ricoh MP 2000 , It was Stuck with error code SC 824 .
    Any help would be great,
    Thank you
  • gkalman2004
    • 157
    Re: Ricoh MP 2000 Stuck with error code
    Originally posted by raveendrala
    Hello,
    Thank you
    Controller or nvram error, usualy the controller is faulty and the nvram is ok.
    If you have a working machine take out the controller with the nvram and test on the faulty one.
    If you change the nvram you will receive sc195 error in this case check the serial number with SP5-811-002.
    • raveendrala
      • Oct 2016
      • 80
      sandmanmac Thank you for RTFM advice
      • raveendrala
        • Oct 2016
        • 80
        I changed Controler Card N(Network ) Problem solved .
        Thank you guys for your help
