RICOH MPC 4502 copies with vertical lines
  • easan
    • Oct 2015
    • 3
    Good morning everyone.!
    We have an abnormal problem with a RICOH MPC 4502 with intermittent vertical lines full page.
    Have cleaned and service the drum units, but the problem is same
    Please see the attachment...
    Can anyone help me?
    Thank you
    Easan
  • aktasson
    • Feb 2017
    • 201
    Re: RICOH MPC 4502 copies with vertical lines
    I would do this first...
    1. SP2109 003 -> 1 (1dot vertical), 2109 005 (select color) --> Copy Window -> press color mode... 3 pages A3 for each color cmy and b/w (press black mode).
    (When the lines occur in each colors + bk so you have to check the cleaning unit, ITB unit and PTR unit.)
    2. Interrupt the copying process by door opening before the paper reaches the PTR unit and then the fusing unit.
    3. It is also possible the cleaning unit of ITB does not clean properly. The pm counters have been checked?
    • Mike R
      • Jul 2015
      • 4
      try replacing the black developer unit, looks lake a bad mag roller
      • andy227
        • Jan 2013
        • 219
        I would go one step further and replace the complete Black pcu. It looks more like a drum/ charge roller issue. Does the drum rotate freely if you turn by hand, or does it bind and make loud rubbing noise ?
        • Mark Bbb
          • Jun 2012
          • 1662
          it would be nice if you told us the lifetime of the pcu and total counter...
          • easan
            • Oct 2015
            • 3
            The pcu condition is good, rotate freely and no rubbing noises.
            Meter reading :-
            Copier B&W : 55258
            Printer B&W : 309553
            we have placed order for new black pcu and will replace it.
            Thanks for sharing the valuable knowledge. it was helpful and thanks again to all
              • 37532
              Meter reading :-
              Copier B&W : 55258
              That is the black. What about the color?
              • davel
                • Oct 2011
                • 1107
                First thing I would have done would be to check PM count on PCU, stop it before fuser check to eliminate fuser, are the lines always in same position. I presume paper is LEF, I hope the grey background is from your camera.
                • LNorris
                  • Sep 2008
                  • 645
                  if u got into sp mode, before selecting the mode, there is a maint tab, select that and then do a print out. the k gets alot more usage than the counter shows. as its used in color as well. ive seen counters at 50k and the pm counter show 100k
                    • 37532
                    MP C4502/5502 do not have maintenance counters as an option from the main SP menu.
