Hi all
I've been having a problem with an MP 3500. The machine is new and the customer recently compliained of grey back ground. On the Tessa site it has a bulletin about this. It recommends making some adjustments to some SP's and a few other things including replacing the dev. I carried out everything on this bulletin, even gave the mag roller a clean. This problem has re-occured within a month, the bulletin also said this was a temp fix as they were still trying to sort a fix for it. Has anyone got any ideas and do you know if they have found a fix. Nothing on the Ricoh site about a conclusion....
