mpc3500 photoconductor units are not set correctly
  • vga_man
    • 78
    [Misc] mpc3500 photoconductor units are not set correctly
    Hello,Good Day!
    Now MPC3500 displayes a message photoconductor units are not set correctly
    Cyan,magenta
    After copying 300 paper and I think there are a electrical shock
    Check female socket and male pins .. Every thing in place.
    Resetting units although doesn't help, checked wired from board to socket seems good.
    Any ideas?
  • copier tech
    • 8182
    Re: mpc3500 photoconductor units are not set correctly
    Have you tried fitting new/exchange PCDUs?
    • vga_man
      • 78
      yes i tried
        • 37544
        Check the connector at front between the drum unit and the development unit.
        • vga_man
          • 78
          i have replaced the pcu and nothing changed
          • sandmanmac
            • 3983
            Tell us What led to this situation? Did it happen after the pcu's were initially replaced, or did it just happen on it's own?
            • vga_man
              • 78
              Replaced pcu "magenta only" then made 300 copy,
              After that I smelled that there are smoke or shock
              Checked pcu seems that it's very hot from the back 'socket' and message appeared
              • mdtrinh
                • Aug 2010
                • 68
                Hello,Good Day!
                Cyan,magenta
                Any ideas?
                Here was my situation:
                - Out of blue, got a call from customer said error from MP C3500 display "Photoconductor unit not set correctly". Went to client site, reseated all PCDUs, but problem still there. Power cycle machine, then problem gone and back to normal.
                - A week later, got a call from customer with the same issue. Went to customer site, it was resolved by customer with machine power cycle before we arrived.
                - Few days later, got a call again with same problem. This time, we just replaced all PCDUs from other working machine in the shop. Problem seem to be resolved for three months now.
                - Just noticed from the problem PCDUs, the color PCDU connectors were modified, rough edges, it seem to be modded from k unit, and those units were discard since we do not have any use for them.
                Hope this help.
                • vga_man
                  • 78
                  Hope this help.
                  How to do power cycle?
                    • 37544
                    That information should have been included in your first post.
                    • vga_man
                      • 78
                      Sorry for that
                      • vga_man
                        • 78
                        Up
                        • vga_man
                          • 78
                          any news?
                          dead machine?
                          • sandmanmac
                            • 3983
                            any news?
                            dead machine?
                            By your own account, YOU did something to short-circuit the machine, and you'd like us to guess what you might have touched to cause it?
                            Where you might have dropped a screw? Or which wire you may have pinched?
                            Not going to happen
                            • NeoMatrix
                              Senior Tech.
                              • 3513
                              It would appear that you have replaced all the problem PCU's with all new same black units or same colour units. Have you swapped the two wires in the PCU front connector to allow the correct PCU identification signals.If you modified the drum units you should have swapped the old toner sensor and place it inside the each new PCU.
                              There is a PCU modified chart(PDF) somewhere in the CTN forums. Have a look at the chart for the correct wire orientation.
                              HTH
