af 2022
  • Gab
    • Aug 2015
    • 671
    af 2022
    Press roller remeves from it's position and the two rollers doesn't press each other. I put it in right position but after few copies it removes from proper position again. The side that the gap between 2 rollers appear is that at the green lever. The green lever is ok and not broken. Any idea?
  • TonerMunkeh
    Professional Moron
    • 3865
    Re: af 2022
    Fusing frame broken or pressure roller bearings siezed perhaps?
    Hit it.
    • laitang
      • Nov 2012
      • 627
      Re: af 2022
      Replace pressure roller and it's bearings
        • 37529
        Re: af 2022
        Plastic lower frame broken where the cleaning roller mounts. Replace the fusing unit.
        • copyaction
          • Oct 2007
          • 991
          Re: af 2022
          Someone in an older post had suggested using the type of press roller bearings with the groove around the outer edge that supposed to keep them in place.
          innthe past I have had to end up replacing the fuser.
          • Polarbear
            • Feb 2012
            • 1070
            Re: af 2022
            Agreed.
            If the HOT ROLLER is moving, it is caused by plastic guides in the lower frame - to the inside of the metal brackets that the bearings fit into.
            They break - normally the on left side (furthest from the drive gear) and then the hotroller moves in the direction of the drive gear until the bearings slip out of their guides and this movement causes the loss of pressure between the hot roller and pressure roller.
            The pressure roller is held in place by metal prongs on the metal risers either side of it. On the one side (normally same side as the hot rolelr drive gear) of the pressure roller is a spring that holds the bearing in place. Is it installed correctly? (see attached photo with red arrow pointing towards the spring).
            Press the GREEN button!!
            • Mark Bbb
              • Jun 2012
              • 1662
              Re: af 2022
              The ball bearing holder on the fusing frame is broken at the rear side, so:
              bent the rear of the metal frame of the stripper finger bar thus fixing the rear hot roller ball bearing...
              So, save costs...
              OK?
              • HitMan
                • Aug 2015
                • 170
                Yeah I've done that a few times. Not much point spending money on a device that old. Just make sure there's no movement on the rollers when they are all tensioned up.
                That's what the newer version of those machines have 2 metal bearing stoppers coming down from the fuser pawl plate
