Sc995-02
  • mdfurqan2012
    • 194
    Sc995-02
    Dear all
    I have mp3352sp whose controller become defective i replaced controller but machine generate sc995-03 i enter serial number by sp5811 for 'set' and then 'bicu' then machine need to be rebooted after that machine generates sc995-02 i again check serial number but after entering serial to set then bcu but serial number of novita not change still shows old serial number kindly guide me
  • Polarbear
    • Feb 2012
    • 1070
    Re: Sc995-02
    Originally posted by mdfurqan2012
    Dear all
    Are the NOVITA serial and one you entered not the same? If not you will get that error.
    Was the replacement board new?
    Press the GREEN button!!
    • HitMan
      • Aug 2015
      • 170
      Make sure CAPS lock is on when re entering the serial it might look the same but if it's not capital letters it won't work
      Also are you in factory sp when trying to change this?
      • mdfurqan2012
        • 194
        Re: Sc995-02
        As i mentioned i replace controller board from other machine(not new) sc995-03 occurs after restart sc995-002 i
        input machine serial number mentioned on back cover but sc995-002 occurs then i input serial number as mentioned in novita ram but sc995-03 occurs again.
        • mdfurqan2012
          • 194
          Re: Sc995-02
          Yes i input serial no. From factory sp mode and also make sure that caps lock is on
          • HitMan
            • Aug 2015
            • 170
            Was there an NV ram chip? Did you swap that over?
            • mdfurqan2012
              • 194
              Re: Sc995-02
              First i try the installed nvram on board when issue not resolve then i swap them with defective board's nvram.
                • 37490
                Re: Sc995-02
                Order a new NVram.
                • Juggy
                  Technical Support
                  • Sep 2007
                  • 101
                  Re: Sc995-02
                  Novita serial can't be changed if you want to make mc work match bicu and controller with novita serial number. Else you need to replace nvram and eeprom need to follow correct procedure to get all right.
                  Sent from my Lenovo K33a42 using Tapatalk
                  • Mark Bbb
                    • Jun 2012
                    • 1662
                    Re: Sc995-02
                    What is a "NOVITA" ?
                    • Mark Bbb
                      • Jun 2012
                      • 1662
                      Re: Sc995-02
                      ok, it's like a martini ...
