Toner and Drum compatability for Ricoh MP 201 and MP 301
  • callmefirst
    • Feb 2012
    • 51
    Are the Drum Units and Toner for Ricoh MP201 and MP301 the same, part #s are different, yet they look identical, is the developer different?
  • sandmanmac
    • 3983
    Re: Toner and Drum compatability for Ricoh MP 201 and MP 301
    Toner bottle and toner loading system very different.
    Use type 1515 pcu by either swapping the faceplate with an MP301 PCU, OR snap off the plastic locator pin on the front of the machine and slide it in.
    Quite a few threads about this.
      • 37553
      If you look at a Genuine Ricoh toner bottle, you will see a small box with a number in it, usually three digits. This is the recipe number for the toner and developer. If the recipe number of the toner does not match the developer, you will have CQ problems. If the recipe number of 2 different toner bottles match but they are different product codes, there is a physical difference in the bottles. It could be length, the bottom of the bottle where the bottle motor couples, the quantity of toner or some other difference.
      • Oze
        Ricoh Fanboy
        • Jul 2008
        • 1663
        Agreed...with these two machines it's the different base of the bottle.
        • Polarbear
          • Feb 2012
          • 1070
          Slimslob
          I see the number on the devs but not on the toner bottles? Where is this number located?
          Press the GREEN button!!
          • sturmtrooper
            Copier Combobulator
            • May 2016
            • 587
            Originally posted by Polarbear
            Slimslob
            Next to the box that says components
            Left bottle 1170D toner, right bottle MP301 toner - Imgur
            I believe that is what he means.
              • 37553
              Slimslob
              You're not looking at the lot number on the top of the developer bag are you? The recipe number is usually only 3 digits and is in a small box at the bottom of the label.
              • Polarbear
                • Feb 2012
                • 1070
                Thanks Chaps.
                Ours don't seem to have those. There is only EDP code information on the label
                • copyaction
                  • Oct 2007
                  • 991
                  i thought those would be the same since the 1515pcu appears to work in the 301
                    • 37553
                    Thanks Chaps.
                    The recipe number is the 3 digit number in the box. 160 on one bottle, 514 on the other. Even though the ingredients in both are the same, with different recipe numbers, the ratio of those ingredients are not the same. If your bottles do not have the recipe number they are probably not Genuine Ricoh.
                    • tufbnme
                      • 493
                      Why hassle with trying to adapt a 1515pcu? the type 301 PCUs are about the same price as the 1515 and the toners are cheap too.
                      • sandmanmac
                        • 3983
                        Maybe you get special dealer pricing? but not me (not a lot of us), and the PCU's are just shy of twice the price here.
                        • copyaction
                          • Oct 2007
                          • 991
                          Same here the 301's are almost double the price
                          • sturmtrooper
                            Copier Combobulator
                            • May 2016
                            • 587
                            I just checked and for us as an authorized dealer the 1515PCU supply item and the MP301 PCU as a service part are the same price.
                            I don't know if we are getting any special pricing because we do a fairly low sales volume but are also the only Ricoh dealer for a large, though rural, area.
                            • sandmanmac
                              • 3983
                              That's great for you but it doesn't change the fact that it's about 80% higher for me and many others and that's the answer to the question of why some of us might go through the 2 second 'hassle' of modding the 1515 pcu.
                              A lot of us aren't dealers (me), but we can buy parts.
