Toner and Drum compatability for Ricoh MP 201 and MP 301
  • copyaction
    • Oct 2007
    • 985
    #16
    Re: Toner and Drum compatability for Ricoh MP 201 and MP 301
    Originally posted by sandmanmac
    That's great for you but it doesn't change the fact that it's about 80% higher for me and many others and that's the answer to the question of why some of us might go through the 2 second 'hassle' of modding the 1515 pcu
    Exactly!
    • andy227
      • Jan 2013
      • 219
      #17
      A small addition to this earlier discussion re the mp301 pcu, as it is the same as the mp1515 pcu but with a small modification, so the 161/171 pcu's can be used with the same mod ? Also, does anyone know which drum/dev/cl. blade could be used should anyone want to go down that route ?
      • sandmanmac
        • 3964
        #18
        Obviously "Yes", since they both REQUIRE the use of a type 1515 PCU just like the aformentioned MP201
        • Dumus
          • Feb 2010
          • 79
          #19
          Dev T28
          Toner T2120D,T2220D (A 1022,1027....)
          OPC and blade from Katun.
          Gears + bushing from Alibaba, made in China.
          • Polarbear
            • Feb 2012
            • 1070
            #20
            Just for interest's sake.
            I would like to know how the 1515/161/171/201 pcu hold up in the 301 as there is a vent on the 301 pcu (obviously to vent pressure inside the pcu) as it runs faster than in the previous models.
            Would the potential pressure build up cause toner dusting?
            Press the GREEN button!!
            • Dumus
              • Feb 2010
              • 79
              #21
              Don't forget 120 and 1013.
              This PCU has starting from 12ppm to finish 30ppm .
              Where is stop ????
