ricoh 3800 cmf dull op panel
  • skinnypuppy
    CopierJanitor/Geargluer
    • May 2008
    • 91
    Customer has a 3800 cmf. Operation panel is almost dull to the point where it can no longer be clearly read. Adjusting contrast Knob makes little to no difference. I suspect the LCD display itself to be hooped. I have reseated all connectors and ribbon cables in the panel with no luck.
    I have also tried refitting the cable that goes from printer to the cmf unit with no luck. Anybody else experience this problem and come up with a fix?
  • E Winter
    Usually the lifetime of these panels and backlights is surprisingly long but I'm shure this is an aging related issue unless the display became unreadable from one day to another.
    A good opportunity to talk with the customer (about a new machine) because a repair might be gainless if you consider that this is a machine from anno ~2002 - what might be the next issue?
    • cobiray
      Passing Duplication Xpert
      • Mar 2008
      • 1199
      I've not had this issue with any of the Ricoh line, but the old analog Minolta's had a small lamp that illuminated (back lit?) the displays. I did manage to find a source for the lamps, but soldering them in was a major pain. I've not had any of the displays apart yet, but I would guess there is a similar illuminate in the Ricoh's also.
      • tjvincent
        • 280
        Replace the board with the dial attached to it , common problem on these.
        • skinnypuppy
          • May 2008
          • 91
          dull lcd display
          I think tjvincent has got it I have consulted with another tech on this and he has had this problem and pinpointed it to the small bias transformer on this board. I am in the process of getting the board and will let you know the outcome. Thanks
