SR3090 doc feeder
  • Qball
    • Jun 2013
    • 127
    [Jamming] SR3090 doc feeder
    Has anyone else been dealing with these feeders and the weak feed units they employ? Feeds initially then original stops just after the sep roller.
  • Qball
    • Jun 2013
    • 127
    Re: SR3090 doc feeder
    Originally posted by terramobil
    SR3090 is a finisher, why do you want to insert originals there?
    Son of a... I got that all wrong, didn't I? I'm talking about the double pass doc feeder on the MP C3003.
    • Coptech
      worker drone
      • 460
      I have heard of people wrapping a round of electrical tape around the barrel roller that drives the feed belt. I have not tried it. I think there is a bulletin with a slightly larger diameter barrel roller but I don't think part is available yet. Same old same old...
        • 37490
        Only problem I have had on the Cxx03 document feeders is the edges of the feed belt fraying. Have had the problem on both the SPDF and the ARDF.
        • ruben
          The New Guy
          • Oct 2012
          • 1203
          Seen this a hundred times. Had Ricoh engineer out to check what could be causing it, but even they couldn't figure it out. In the end, we replaced the complete feed assembly: D684-2100, and the problem was cured instantly.
          Note: The part has since been modified, but the old part number is still being used. If you order the assembly, and get two white rollers inside the belt, that is the new assembly; the older assembly has either both black rollers (03 range) or one black and one white (04 range).
          Both 03 and 04 have the same DF fault, so both will need new assemblies.
          See also: http://www.copytechnet.com/forums/ri...tml#post512310
          • Qball
            • Jun 2013
            • 127
            Note: The part has since been modified, but the old part number is still being used. If you order the assembly, and get two white rollers inside the belt, that is the new roller; the older roller has either both black rollers or one black and one white.
            That's exactly what I did on these two gems I worked on. Good to know about the updated part.
