How to set Function Priority on an Ricoh 04 (android) machine?
  • ElDiablo
    • Nov 2011
    • 5
    Hi everyone,
    Is it possible to set the function priority on the fancy Ricoh 04 models through the Web Image Monitor?
    It used to be possible to set this through the Web Image Monitor but the option doesn't appear to be there now.
    Does anyone know how to do this?
    I know you can set it through the panel but on a big roll out (or working remotely) this can be a pain.
    Cheers
  • sparks45
    • Jun 2014
    • 25
    Re: How to set Function Priority on an Ricoh 04 (android) machine?
    It doesnt look like you can anymore, can still set the function keys but not the priority
    • ElDiablo
      • Nov 2011
      • 5
      Good 'ole Ricoh... if correct, that's a lovely step back from what we had before.
      • TonerMunkeh
        Professional Moron
        • 3865
        User Tools / Screen Features / Screen Device Settings / Function Priority.
        Hit it.
        • ElDiablo
          • Nov 2011
          • 5
          And through the WIM?
          • FrohnB
            • Jul 2017
            • 1919
            ElDiablo, they have the SOP (Smart Operation Panel) designer now, with that, you can load logos/wallpapers, send meter app, set your FUNCTION keys and PRIORITY and the list goes on. I believe you can do this on 10 machines at the same time. Do you have any kind of Ricoh credentials to access their site to download? Seems like they have it locked down pretty well, and not available to download anywhere except their TSRC site.
            Omertà
            • JaysOnTheEDGE
              • 61
              I may be wrong but I believe it's done through the smart operation panel design tool. I know it can be done as we are doing a equitrac rollout and the person doing the remote configuration is setting up equitrac as the priority after configuration.
              Sent from my SAMSUNG-SM-G530AZ using Tapatalk
              • ElDiablo
                • Nov 2011
                • 5
                Nice one. I'll check it out. Sounds like it might be useful in the big roll outs.
                Edit: Still be nice to able to change it via WIM, for small installs or one off devices though.
                Cheers
                • ElDiablo
                  • Nov 2011
                  • 5
                  Thanks. Sounds like the way forward on the big installs.
