Ricoh Aficio 3025 SD card print/scan option
  • 1039
    • Jul 2025
    Hi!
    I not have the SD card print/scan option. Can i use any SD card and download the software needed?
    Or may be buy on Aliexpress Compatible For Ricoh 3025 printer card scanner kit MP3025 sd card
    Somebody has an experience ?
    • 37490
    Re: Ricoh Aficio 3025 SD card print/scan option
    Originally posted by 1039
    Hi!
    No unless you have a way to do a sector by sector copy from one SD card to another. Of course you would have to have an SD card and would be running the risk of copyright infringement.
    Looks like the Ricoh SD card other than it should a type 3030. But why would pay $38.88 US when you can get one on Ebay for $9.95. Either way you still might not be able to print and scan unless the machine already has an HDD and the additional memory required. Your best bet is to get a complete Printer/Scanner kit from somewhere like recycledparts.com. It will give you everything you will need. 412597 Print Scanner Option B767 Type 3030
    • 1039
      Ok. Thanks.
      I have HDD and the additional memory 256 Mb. Need only SD card print/scan option.
      unfortunately on eBay I haven't found the card.
        • 37490
        Ok. Thanks.
        Ricoh type 3030 printer scanner unit AB76757 | eBay
        • 1039
          Ok. Thanks.
          I have bought this card. I will try to use
          • 1039
            Ok. Thanks.
            it's all right
