Ricoh Aficio 3025 SD card print/scan option
Tags: None
Re: Ricoh Aficio 3025 SD card print/scan option
1039
No unless you have a way to do a sector by sector copy from one SD card to another. Of course you would have to have an SD card and would be running the risk of copyright infringement.
Looks like the Ricoh SD card other than it should a type 3030. But why would pay $38.88 US when you can get one on Ebay for $9.95. Either way you still might not be able to print and scan unless the machine already has an HDD and the additional memory required. Your best bet is to get a complete Printer/Scanner kit from somewhere like recycledparts.com. It will give you everything you will need. 412597 Print Scanner Option B767 Type 3030
I have HDD and the additional memory 256 Mb. Need only SD card print/scan option.
unfortunately on eBay I haven't found the card.Comment
I have bought this card. I will try to useComment
1039
