MP-2851
  • aAandy
    • Apr 2012
    • 370
    [CQ] MP-2851
    Hey Guys
    here's a head stomper for you,,
    this machine prints beautifully, it scans to email beautifully & you can print out that scan just fine - but COPY?? comes out faded as! same result from ADF or platen copy
    client said it happened suddenly, not gradually
    even after setting everything imaginable to the darkest setting, in service mode, the best i could manage is a far cry from what it should be
    Ricoh MP2851 samples.pdf
    anyone got any suggestions?
    thanks in advance
  • sandmanmac
    • 3981
    Re: MP-2851
    Very common. Tons of threads about this
    Replace PCU.
    Yes, I know it would seem that print quality and copy quality should not differ so much, but they do, as the PCU nears the end of its life.
    • copyaction
      • Oct 2007
      • 991
      Re: MP-2851
      Replace PCU.
      sandmanmac nailed it, replace pcu
        • 37533
        Re: MP-2851
        Return all settings you change to where they were before. Since it happened suddenly, check to see anyone change the original type from Text to Text/Photo. Also clean all mirrors, the face of the lens and the bottom of the glass under the scale. After cleaning cycle the main power off then on to force a white reference scan. If the white reference is off and you are in Text/Photo original setting, you WILL get light image. Unless an original has multiple shades of grey that you need reproduced, i.e. a photo, never use Text/Photo. Blacks will be rendered in grey scale and not high contrast B/W.
        • copyaction
          • Oct 2007
          • 991
          Re: MP-2851
          Definitely do all those too, but most of that would affect scans as well.
            • 37533
            Re: MP-2851
            Changing default copy function original type to Text/Photo will not affect scans.
            PCU would not change suddenly.
            • aAandy
              • Apr 2012
              • 370
              Re: MP-2851
              UPDATE
              a previous repair organisation had attempted to repair the machine and had done the following prior to my attending: (i hope you have your auto-translating glasses on)
              MP-2851 prev work done.pdf
              looks like they fitted a new PCU and a bunch of other stuff - i fitted a new PCU anyway and it made no difference, checked the text/photo bizzo, it was on text only
              naturally the very first thing done is a thorough clean of the optics, slit & platen glasses, white reference plate, exp lamp & reflectors, mirrors, lens and if accessible the CCD face
              told ya it would be a head-stomper
              internal prints perfect
              prints perfect
              scans perfect
              prints the scan perfectly
              copies like a wet paper bag
              i now know what's wrong with it,,,,,
              it's broken!!
              • Lagonda
                • Aug 2008
                • 1649
                Re: MP-2851
                Pull the cover off the lens housing and check that the CCD chip hasn't started to come unglued and isn't sitting parallel to the lens. I've seen this a couple of times on this model. Just a drop of Supaglue does the trick.
                • Coptech
                  worker drone
                  • 460
                  Re: MP-2851
                  sp2907 on old machines default is 5 later machines are 6 or 7. Set them to 10 which is the max. It is a line width during copy in different modes.
                  • gkalchik
                    • Jul 2017
                    • 19
                    Re: MP-2851
                    I can attest to this SP setting.
                    Long ago when I started to service these line of Ricoh copiers I just automatically changed the settings of this SP to max.
