Ricoh MPC3002 makes some noise when starting up or before printing
  • druckerteam
    • Oct 2015
    • 28
    Hello.
    I have this problem, that two of our MPC3002 makes this like in the video.
    We changed the fuser, but the noise is still there.
    Do anybody have a idea how to fix it?
    Thanks!
    Regards, Paul
  • TonerMunkeh
    Professional Moron
    • 3865
    Re: Ricoh MPC3002 makes some noise when starting up or before printing
    That sounds like it's coming from the pressure roller contact mechanism. Check the sensor and drive gear in the machine.
    Hit it.
    • COPIERMAN
      • Jun 2009
      • 559
      have you tried in service mode output check try turning on different motors and see which motor makes the noise happen.
      • druckerteam
        • Oct 2015
        • 28
        Hello.
        Thank you very much guys.
        Could you tell me the number in service mode?
        Sorry but our technician is in holiday and I cant find it
        Thanks!!!!
        • COPIERMAN
          • Jun 2009
          • 559
          Are you a tech if not need to wait for him to come back.
          • copier tech
            • 8186
            That is the half moon type gear slipping (the pressure roller contact motor) you can adjust the timing with SP1151-002/3/4 set to around 800 usually does the trick.
            Also I beleive updating the firmware corrects this for you.
            • negrete
              • Oct 2013
              • 9
              Originally posted by druckerteam
              https://youtu.be/JRAqAs2dN6o
              Hello.
              Thanks!
              Regards, Paul
              This defect is on the PCB BICU, You should change.
              • StephenB
                • Aug 2015
                • 244
                Had the same thing happen on a couple of MP c 3002's, Try using SP 1-151-001 pressure setting - pressure change- and set to off. Fixed my problem. Has been over 6 months now.
                • Ivan FSA
                  • Apr 2014
                  • 6
                  Hi guy,
                  Set this values and will be happy!
                  Bye!
                  Hello.
                  Thanks!
                  Regards, Paul
