MPc5502 not recognizing new toner
  • techsass
    • Dec 2010
    • 248
    I have to meet a tech Monday that has an MPc5502 that keeps saying to insert a new black toner bottle. This is not an ADD TONER issue. He updated the firmware & was able to run copies afterwards, but the message showed up just as he was getting his ticket signed and he can't get past it.
    He's already tried 2 new bottles, replaced the RFID and replaced the IOB pcb. He also downloaded & installed the firmware that just came out last week.
    Any ideas??? The only thing I can think of off hand is to re-initialize the engine.
    Thanks for any & all ideas.
  • ruben
    The New Guy
    • Oct 2012
    • 1203
    Re: MPc5502 not recognizing new toner
    Usually this is caused by a faulty pump, but can sometimes be a faulty or shorted TD sensor.
    Toner end flow chart: toner end conditions.pdf
    S26
    S27
    S28
    S29
    Toner End Sensor - K
    Toner End Sensor - Y
    Toner End Sensor - C
    Toner End Sensor - M
    CN207/B14
    CN207/B3
    CN207/B9
    CN207/B6
    Open Toner end cannot be
    detected.
    Shorted Toner end is detected
    when there is enough
    toner.
    • techsass
      • Dec 2010
      • 248
      Appreciate the response, but this isn't a false add toner issue. The copier isn't recognizing the new toner bottle. Sp3045 doesn't help, etc.
      • copier tech
        • 8119
        What is the EXACT message?
        • Brianneoe
          • May 2015
          • 318
          Since he updated the firmware as all good techs should, and then the problem appeared, I would check that the machine is not a RM unit that needs a different engine firmware version. I had this problem and the correct firmware corrected it.
          Engine
          9/26/2016
          D143-D144RM_Engine_v1.11a.04_SDCard NOTE: Engine firmware to be used on Greenline Series(RM Models) D111-D142 and D143-D144 Only.
          Engine
          7/28/2017
          Engine
          7/28/2017
          • techsass
            • Dec 2010
            • 248
            Engine
            9/26/2016
            Engine
            7/28/2017
            Engine
            7/28/2017
            Awesome!!! Strange how tech support was unaware of this.
            Will post the actual message after I get out there.
            • techsass
              • Dec 2010
              • 248
              First off the display says "Toner Cartridge Setting Error".
              It is a known issue according to Ricoh Tech support. As Brianneoe stated there is a specific Engine firmware for the Greenline version - 1.11a.04. It doesn't tell you that on esource, but there is a message in the readme saying it's only for machines whose S# has an RM suffix. Usually you can just load the correct firmware and you're back up & running. Usually, but not today. I even tried going back 2 versions of the Engine firmware.
              Tried an Engine clear without any luck. Reseated the new RFID pcb, but still no luck.
              I then reseated the BCU eeprom and all their print jobs started coming out.
              I then shut it down to remove the nvram backup SD card. When I turned it back on my error was back. Reseated the eeprom a few more times, but it never came back to ready.
              Hopefully a new eeprom will do the trick.
              • sibleyrc
                • May 2015
                • 4
                I had the same issue when I "accidentally" updated the firmware on NON greenline copier using the GREENLINE engine firmware. Reverting to the correct engine firmware corrected the issue.
