Toner supply pump question for the McGYVERS out there
  • fshead
    • 2376
    hi
    I HAVE A BOX OF 15 BAD TONER pumps sitting on the side that i just bought
    on ebat the rubber pump piece that goes bad.
    Anyone pull one apart yet?
    and if so anything to look out for or learned from doing it?
    below is the part number and models i reference
    thanks
    W523-2110 Toner Pump Rubber Pumps Ricoh MP C2000 C2800 C2500 C3000 C3001
  • copier tech
    • 8192
    Re: Toner supply pump question for the McGYVERS out there
    Why would you buy broken toner pumps?
    To buy brand new they are dirt cheap!
    • mdtrinh
      • Aug 2010
      • 68
      Originally posted by fshead
      hi
      thanks
      I just tried to replace one with rubber piece, it was very hard to do due to lock tab was very easy to break, and it did not work after all the hard work.
      Just my experience, I don't know everybody else successful with it.
      Better off with new unit from ebay.
      • fshead
        • 2376
        thats funny..
        no i did not but bad pumps,just saved the old ones when i replaced them
        plus some from parting out "parts machines".
        and they are not cheap here in usa,over 100 bucks...
        so i ended up pulling one apart,small c clip n the clutch out and then the secret to
        pulling the plastic up w/out snapping the housing>>fishing hooks.
        i went thru my tackle box and pulled out 3 gamagatsu circle hooks and they got under and
        allowed me to pull unit apart..what i see as the problem is not that the rubber plug/pump?
        wears out but the inside housing that has a metal worm type gear inside that is driven via the clutch..
        so i am going to use a hot glue gun to rehouse the shaft to the rubber and will let you know after i
        swap one out..i did order 10 rubber plugs and will try them too.
          • 37556
          The shaft has to turn in the rubber. That is the actual pump action.
          • fshead
            • 2376
            yeah i kinda notice that the rubber piece does not spin after reassembly w/out doing any mods
            or glue..'so the toner passes thru the plug?
            its an odd design..
              • 37556
              its an odd design..
              Actually it is a very common design. Not only pumps the toner but insures particles passed though are not too large. The Aficio 551/700/1055 in the waste toner unit to separate recyclable toner from the waste.
              • Cipher
                It's not easy being green
                • May 2006
                • 1309
                Toner attraction pump is not really a good description.
                It's a mechanical driven auger shaft (or screw if you like) that moves toner along a short chamber at a fixed rate to a exit point.
                The attraction part is no doubt the small amount of directional air pressure the movement generates that helps the toner flow out from the supply tube.
                But it's not really what I would call a pump in the traditional sense though.
                As it has no oscillating diaphragm like in air pump or propeller wheel like in a water pump.
                Main issues that come to mind.
                • Magnetic clutch failure.
                • Too much rotational torque.
                • Insufficient air pressure.
                • fshead
                  • 2376
                  i never saw any 551 sand started selling the 1060s after i switched over from
                  doing sharps and minolta for 15 years or more...so that metal "auger" pulls the fine toner from the center of the rubber plug?
                  if so can i mechanically turn the shaft with a hose with toner attached and test that it works?
                  i just pulled a 2nd apart and the was a few big chunks of cyan toner,so i cant say a clogged pump
                  cleaned out will work well.
                  • tufbnme
                    • 493
                    Its not the rubber that is the problem, it is the clutch that turns the shaft. You will notice that the clutch is larger on newer pumps. I have taken them apart and cleaned them but it was a waste of time. They are inexpensive, just replace.
                    • fshead
                      • 2376
                      THANKS
                      can you buy the clutch and if so do you have a part number?
                      Did you pop off the retaining ring
                      and check the clutch face?
                      The reason i was pointed towards the rubber piece as it would make sense since it will deteriorate
                      with toner contact over time,plus it looks like a positive feedback from buyers on EBAY..
                      • tufbnme
                        • 493
                        Cannot purchase the clutch.
                        • dzewo
                          • Oct 2013
                          • 36
                          If memory serves me right I saw a bulletin on the pump problem and it stated that the rubber inside was the culprit. I ordered a few of them from China but the results were rather poor. The voltage drop wasn't as high as with the new units (talking about forced toner supply), the disassembly was quite problematic (latches liked to break) and the pumps were rendered useless quicker than I expected. A new black pump costs ~60$ (the bulletin stated that they changed sth to imporve it) and lasts much, much longer.
                          • fshead
                            • 2376
                            The voltage drop wasn't as high as with the new units...??
                            not sure how you know that or who checks for such.
                            by accident i bought some mpc3000 toner pumps and that clutch is twice the
                            size as mpc2800/c3300 clutches..
                            from what i see they too had issues.
                            i completely dissassembled the cutch units and cleaned with air, and then cleaned all
                            with acetone"was a lot of surface grit,dirt on clutch faces".
                            I have yet to use any of my newly rebuilts but will post results once i do..
                            my cost as a non dealer is twice what you quote thus why i would
                            venture for a cost effective solution.
                            • fshead
                              • 2376
                              well i installed first rebuilt pump and it worked with no hiccups..the only thing i will add is i try not to keep them near heat"i dont let them bake in my pickup when the summer temps hit 90s.
                              and there is not a flec of toner inside either,,,,,,,,,,,
