ghosting/double image
  • liwiza
    • Aug 2008
    • 4
    hi guys
    this is my first entry and hope you guys can help
    i'm from Nashua in SA and moved to NZ and work for Ricoh now
    help needed with firmware for AF1013mfp ghosting
    changed pcu and fuser parts still ghosting
    cheers
    liwiza
  • cobiray
    Passing Duplication Xpert
    • Mar 2008
    • 1199
    Check the drum ground for good continuity. You should have very close to zero Ohms if you check t with a meter to the frame. You might need a drum shaft or bearing replaced.
    • cobiray
      • Mar 2008
      • 1199
      How about the erase lamp? Have you check it? Cleaned it?
      • liwiza
        • Aug 2008
        • 4
        hi
        i'll give it a try and let you know
        cheers
        liwiza
        • Cipher
          It's not easy being green
          • May 2006
          • 1309
          If that fails try another pressure roller and check the plastic bushings are not dug out.
          I'm sure I had image repeating issue on this model a few years back and this is what it turned out to be in the end.
          I remember because it was a bit of a strange one.
          • liwiza
            • Aug 2008
            • 4
            hi cipher
            cheers for that we have replaced both hot and pressure roller and bushings are ok
            i know we had firmware that solved this fault in SA but cannot find it here
            cheers
            liwiza
            • FRIDGEMAGNET
              • Aug 2007
              • 377
              Originally posted by liwiza
              hi cipher
              cheers
              liwiza
              The FCU firmware has a release note that says it cures ghosting.
              Sometimes, the operator can clear a fusing SC error with power Off/On
              (see RTB RB044014 for details). - version 91
              �� Offset images - version 90
              �� Offset images on the right side only. - version 88
              This is firmware for EU/NA and Asia - not sure about your Pan Asia area.
