mp c306 Firmware update
  • fireater
    Repair God? not quite
    • Apr 2006
    • 253
    Did anyone get the Online Firmware update in SP Mode working? Mine says "Cannot use this function" E71 (Yes It is registered with @ Remote if that matters)
    I fix copiers ...Well Sorta
    • 37529
    Re: mp c306 Firmware update
    Did you try reading the service manual section on Error Screens During Updating?
    • ruben
      The New Guy
      • Oct 2012
      • 1203
      Never managed to get it to work, so always update manually.
      • copier tech
        • 8169
        All our machines are on @remote (if the install engineers remener to add the code!)
        On the machines that dont connect updating the fw first via SD card then enables update via service mode/@remote to work.
        The later android models with G2 panels dont need @remote to install fw from service mode works straight out of the box.
        • fireater
          • Apr 2006
          • 253
          Must be our stupid firewall that out Weirdo I.T. guy has in place ..sigh
          • fireater
            • Apr 2006
            • 253
            found a blurb in the service manual.. . do they need a HDD to do the remote firmware?.. would make sense. Without hdd there is no place to download the firmware
