C2503 PM supplies
  • tinfox
    • 317
    C2503 PM supplies
    I'm doing my first drum developer replacement.
    I see there is no developer material packet available, so I'm assuming when ordering D1773020 that it will contain black developer?
    The other drums/devs are near there pm limits. Is there a kit that will have all the drums and developer units?
    Thanks!
  • copier tech
    • 8195
    Re: C2503 PM supplies
    PM life is 60k for the PCU & 120K for the developers.
    Personally I replace the black PCU & dev as a set, the dev units are pretty poor compared to the MPC3003 series.
    Dev unit comes with developer in the unit.
    PCU (all for the same) D1882254
    K Dev unit D1773025
    • tinfox
      • 317
      Great Thanks!
      So I need to order the four separate developers and four drums? The drums are the same?
      • copier tech
        • 8195
        Originally posted by tinfox
        Great Thanks!
        Yes that is correct.
          • 37560
          Great Thanks!
          Are all four PCDU beyond PM count? If not, only replace those that are.
          • tinfox
            • 317
            No just the black, but the others are very close.
            • Mark Bbb
              • Jun 2012
              • 1662
              If you replace only developer or pcu, you look at a bunch of work!
              Just did that previous moth, parts are expensive, which much time on PM interventions needed!
              As mentioned, PM's for c3003 (-2, -1) are much better...
              • sturmtrooper
                Copier Combobulator
                • May 2016
                • 587
                Sadly these are low end budget models. I'm really hoping the replacement C2004/2504 are better but won't hold my breath.
                Our shop mostly only replaces color parts when the quality goes bad, unless they are far far beyond PM count. Seems to work ok.
