PS3 recovery from a "per total" c2051
  • Mark Bbb
    • Jun 2012
    • 1662
    Hello,
    "this software is already in use for another machine"
    Is there a way to overrule this issue?
    Greetings,
    Mark
  • davel
    • Oct 2011
    • 1077
    Re: PS3 recovery from a "per total" c2051
    Buy a new PS option.
    • COPIERMAN
      • Jun 2009
      • 559
      If postscript came out of a different copier it will say this. when they install it new they match serial # and Now it doesn't match. i just tell customer that the postscript is fine and it was pull out of another copier. they are happy with it and i tell them if they what to get rid of message will need to buy a new one.
      • Mark Bbb
        • Jun 2012
        • 1662
        Copierman: will it work despite this message?
        • KenB
          Geek Extraordinaire
          • Dec 2007
          • 3945
          Not that I have ever seen, it won't.
          • COPIERMAN
            • Jun 2009
            • 559
            have done plenty of copiers this way. When customer wants Ps3 and this message comes up. our copier company does refurb copiers only so we do this all the time. We are in the Untied states if your are overseas might be different.
            • copier tech
              • 8101
              Upgrade to a new 'ex' machine, postscript is included by default, at last Ricoh!
              • ruben
                The New Guy
                • Oct 2012
                • 1203
                Emulated PostScript is included by default, true PostScript is still an option.
                Emulated is, essentially, just as good (unless the customer wants a better colour quality).
                • KenB
                  Geek Extraordinaire
                  • Dec 2007
                  • 3945
                  If nothing else, the emulated PS will prevent those *wonderful* little situations where the sales person neglected to ask if there were any Macs that needed to print.
                    • 36831
                    I could be wrong , but I don't believe embedded Postscript emulation was available before the CXX03 models.
                    • KenB
                      Geek Extraordinaire
                      • Dec 2007
                      • 3945
                      I've not yet seen Ricoh emulated PostScript in action.
                      Hopefully, it's better than others I have seen in the past, although it has been a number of years.
                      I hope that salespeople don't take it as "Oh, look! Free PostScript!".
                      I'm sure that higher end apps won't like it; they're designed to use the real McCoy.
                        • 36831
                        It is not, other than the PDF direct portion.
                        • Mark Bbb
                          • Jun 2012
                          • 1662
                          Copier tech: sorry, what do you mean?
                          • KenB
                            Geek Extraordinaire
                            • Dec 2007
                            • 3945
                            About what I figured.
                            • Mark Bbb
                              • Jun 2012
                              • 1662
                              So gentlemen,
                              Resuming: there is a free PS from Ricoh, but for graphics that's not an improvement...
                              The only way around it is to buy a new one.
                              Thank you all kindly for your answers and help, have a good weekend.
                              Mark
