Re: vertical fading
it could be a piece of paper that constantly is rubbing against the drum, so removing toner from the surface of the drum.
I have had this a few times.
But... if you have replaced the pcu cartridge it is more likely there is a laser problem.
But when it was a laser problem it would be the same problem on 1 color of the 3 to (because the polygon is treating 2 colors at the same time), which isn't the case...
Strange phenomena.
Strange phenomena.
