Ricoh and apple scan to folder Issue
  • COPIERMAN
    • Jun 2009
    • 559
    does anyone know if they fixed scan to folder issue for a apple computer with there new copiers. I know in past there were software changes to the computer to make it work.
  • sturmtrooper
    Copier Combobulator
    • May 2016
    • 587
    Re: Ricoh and apple scan to folder Issue
    As far as I know FTP scanning works just fine on apples, though you do have to set up an FTP server, no idea about SMB.
      • 37508
      The latest firmware for the SOP fully supports SMB v2/v3. See file link in post 18 by Copier Tech in this thread. Also file sharing might need to be turned on for the MAC.
      http://www.copytechnet.com/forums/co...-update-2.html
      • Ricohguy
        • Sep 2012
        • 48
        This currently only applies to the 04 and 04ex color models and the 03 color models. The remaining copiers are 'coming soon'.
        • Brianneoe
          • May 2015
          • 320
          Go into terminal, to start it type in:
          sudo -s launchctl load -w /System/Library/LaunchDaemons/ftp.plist
          then press return.
          To stop it type in:
          sudo -s launchctl unload -w /System/Library/LaunchDaemons/ftp.plist
          and press return.
          Create a Scan folder and share it at the root. At the desktop click on the "Go" icon and then "Home". Here is where you want to create your folders.
          Right click the folder and go to "get info". Here is where you set up your share rights.
          After you share it out you will want to right click the folder and select "Make Alias". A second folder will be created with a arrow. Drag this folder and move it to your desktop, this is your short cut to that home folder
          On the newer MACs after you turn on FTP you will see at start up something similar to a DOS start up command.That is the FTP services turning on.
          The only drawback on using FTP is that you need to use the IP address. Once in awhile I will need to walk my customer through on how to fix up their scan paths.
          • MitchD
            • Oct 2012
            • 164
            Bingo! I have been doing this the few few months and its been a solid solution for Mac users that have to have scan to folder. Very easy set up and very few drawbacks
            then press return.
            To stop it type in:
            and press return.
            "Heavy music to the normal ear is nothing but a loud annoyance. Most people think of it as obnoxious, talentless music but to someone who really listens and is really in love with music knows how beautiful and amazing it can be" Tommy Rogers of Between The Buried and Me"
