ADF JAMMED
  • lawchatkui
    • Aug 2017
    • 79
    ADF JAMMED
    Mpc3500 the feed paper ( for doing double sided copying) comes out directly from ADF like single side copying, & red light on - jam at P, anyone can help, thank you
    Sent from my Mi 4i using Tapatalk
  • Polarbear
    • Feb 2012
    • 1070
    Re: ADF JAMMED
    Hi LAWCHATKUI
    Seems like the solenoid that operates the reverse flap in the df is stuck. Take a listen, as you should be able to hear the flap activate once the first side of the original has been completely scanned. If you cannot hear it, it is not operating.
    The machine knows that you want to make a duplex copy, but the original is fed out the single path and therefore it registers a jam.
    Check that the flap (paddle) that operates the duplex mechanism is not stuck. It used to happen a lot on machines that did not make many duplex copies. a Little lubrication and manual assistance, and all will be well again.
    Press the GREEN button!!
    • lawchatkui
      • Aug 2017
      • 79
      Re: ADF JAMMED
      Thank you very much Polabear for ur advice, I will look into it
        • 37491
        Re: ADF JAMMED
        With the number of questions you have posted today on the MP C3500, my suggestion is that you call your nearest authorized Ricoh dealer.
        • lawchatkui
          • Aug 2017
          • 79
          Re: ADF JAMMED
          Pro slimslob, u r right, I m a beginner in color machine, 1st time join the forum & never hv a mentor lead me a right way, thus lots of questions once join in, all pro sorry my negligence to bother you all. I apologize for any inconveniences caused.
          • NeoMatrix
            Senior Tech.
            • 3513
            Re: ADF JAMMED
            lawchatkui, you're a very active guy on the forum(s) at the moment.
            Asking copier questions is a good thing, getting all the guys to repeat the same out dated answers is probably not so good.
            If you will, I would like to show you how to search the old CTN forums for all the old copier answers your looking for.
            In any web browser using any search engine, type in the following (without quotes)
            "search site:wwwcopytechnet.com <my copier fault>"
            Example, entire full text type into google search engine:
            search site : www.copytechnet.com MPC3500 jamb
            You can read your web browsing interest back for about 10 years of forum posts.
            HTH
            • lawchatkui
              • Aug 2017
              • 79
              Re: ADF JAMMED
              HTH
              NeoMatrix, i m new here, so not familiar the condition yet, thank you very much for ur advice[emoji106] [emoji108]
