Mpc3500 print from computer very dark
  • lawchatkui
    • Aug 2017
    • 79
    All. Pro, anyone know where can I make the adjustments for mpc3500 if the print out from computer the results turn out to be very dark in color as compare to the Original photo?
    As in copying mode, I can do the lighten adjustment, but print from computer, where is the way to rectify it? Tq
    Sent from my Mi 4i using Tapatalk
  • TonerMunkeh
    Professional Moron
    • 3865
    Hit it.
      Re: Mpc3500 print from computer very dark
      depending on the operating system... and which print driver you are using, the print driver might have a limited set of controls.
      are you an end user or tech?
      • lawchatkui
        • Aug 2017
        • 79
        Yeah I see, but the copying of photo with the lighter the color print out quite acceptable. So pro could you enlighten the where can I amend it when Printing from computer? In toner save mode?
        • lawchatkui
          • Aug 2017
          • 79
          I m tech
          • lawchatkui
            • Aug 2017
            • 79
            The driver use mpc3500 pcl6
              you would make adjustments in color mode and save that profile...
              • lawchatkui
                • Aug 2017
                • 79
                Pro, seem that only with option true24bit color & monochrome
                • lawchatkui
                  • Aug 2017
                  • 79
                  I can't find anyway to lighter the color contrast, or can u advise me where can I make the adjustments in SP mode? Thanks
                    you would have to go to the manual for that
                    • lawchatkui
                      • Aug 2017
                      • 79
                      I hv manual but not quite sure where should I starting from, quite confused, haha, anyway thank you pro
                      • davel
                        • Oct 2011
                        • 1111
                        clean optics and music sensors when you find them do line position adjustment then ACC for copy and all printer modes.
                        • lawchatkui
                          • Aug 2017
                          • 79
                          Davel, sorry may I know where is the music sensor located? Thanks
                            • 37695
                            You can start with Auto Color Calibration in User Tools. As always, clean optics first, then run ACC for copying to calibrate the scanner then run all printer ACC.
                            Try installing the RPCS driver and turning on Toner saving.
                            • sturmtrooper
                              Copier Combobulator
                              • May 2016
                              • 587
                              Printer SP 1106 will allow you to adjust the toner limit for printing. Reducing the number reduces the max toner amount.
