Ricoh MP C3500 Technician Wanted, Columbia, SC
  • ISLEVIBES
    • Mar 2014
    • 20
    I have two MP c3500 that keeps telling me to add toner. I need a reliable technician to fix my copiers and give me service on a regular basis.
    My name is George you can call me at three four 7 329-8930 New York number but i am in Columbia, SC
    • 37533
    Re: Ricoh MP C3500 Technician Wanted, Columbia, SC
    There is a forum specifically for Employment. Use it. This forum is for technical problems.
    • lawchatkui
      • Aug 2017
      • 79
      Bro change the pump rubber will fix the problem.
      Sent from my Mi 4i using Tapatalk
      • lawchatkui
        • Aug 2017
        • 79
        If failed vacuum the pump tub should be Ok
        • davel
          • Oct 2011
          • 1107
          you need to change complete pump with a new one.I
          • jimmycabral
            • Jun 2016
            • 35
            check the Nozzle Ass'y, it has toner end sensor that maybe need to clean...
            • ISLEVIBES
              • Mar 2014
              • 20
              I changed the pump still no toner mess. I just need a tech in my area that i can rely on. How can i find a tech in my area without going to a big company.
              • lawchatkui
                • Aug 2017
                • 79
                I never met any toner issue after changing only the pump inside "rubber", if still problem insisted just vacuum clean the nozzle part & tub sure workable.
                • lawchatkui
                  • Aug 2017
                  • 79
                  Most of 90% the issue due to the rubber inside the pump got hardened, 10% caused by hardened toner jam in the nozzle assembly.
                  • fshead
                    • 2376
                    I just received 10 rubber pumps replacements and will try on my stash of mpc3300 failed pumps...
                    i am going to use my soldering iron to scribe them with a name so i know if they work or fail after
                    swapped out in field...this is not for an end user
                    • ISLEVIBES
                      • Mar 2014
                      • 20
                      Ok let me know
                      Sent from my LGLS676 using Tapatalk
                      • lawchatkui
                        • Aug 2017
                        • 79
                        There are 3 clicks to separate the pump motor for rubber replacement, be careful don't broken it otherwise it won't work.
                        • lawchatkui
                          • Aug 2017
                          • 79
                          Quite tough the job, you tube video shown before the ways to make it, try search on it.
                          • fshead
                            • 2376
                            i have 5 of them already split open.
                            i end up using sharp fish hooks to get under and then
                            a small metal angle i made to clear tab..
                            • ISLEVIBES
                              • Mar 2014
                              • 20
                              Ok, I will replace the rubber, but when I first replaced the entire yellow toner pump and swapped out the yellow developer my calibration print out was faded and very light. all four colors. So after i get the toners pumping i have to figure out what caused this to happen. Any suggestions?
