Mp 6500
  • andywong90
    • Mar 2013
    • 110
    Mp 6500
    Guys, what problem ricoh mp6500 reading vsp 5.0 ,copy out blur
  • andy227
    • Jan 2013
    • 219
    Re: Mp 6500
    ID sensor output is abnormal when Vsp showing 5. Pull out the drum assembly and check the ID sensor, it may be covered in toner, the toner may be so piled up high on the guide that it touches the drum, and hence the blurry copies. Clean it out, and re-check. If the same, try another sensor/drum assembly, and possibly the drum itself.
    • jonhiker
      • 661
      Re: Mp 6500
      Pull out the dv unit and the pcu. clean the pcu unit. also, check an clean what they call the classification assy, it is the clear plastic thing on top of the toner supply unit. Then, run a few partial sky shots and see if it then re-balances the vsp/vsg. You may need to change the developer.
      • hsh6049
        • Jul 2012
        • 64
        Re: Mp 6500
        [QUOTE=jonhiker;573422]Pull out the dv unit and the pcu. clean the pcu unit. also, check an clean what they call the classification assy, it is the clear plastic thing on top of the toner supply unit. Then, run a few partial sky shots and see if it then re-balances the vsp/vsg. You may need to change the developer.[/QU
        hi may i know what is the PCU ? i am also facing the same problem with the reading suddelny vsp&vsg reading 5.0
        • davel
          • Oct 2011
          • 1104
          Re: Mp 6500
          [QUOTE=hsh6049;580937]
          If you have to ask what is pcu you are not a technician, call a real tech.
          • hsh6049
            • Jul 2012
            • 64
            Re: Mp 6500
            [QUOTE=davel;580945]
            we name pcu unit.as drum unit
              Re: Mp 6500
              ARE YOU A TECH?
