aficio 2045
  • Gab
    • Aug 2015
    • 656
    aficio 2045
    Paper jam when it pulls paper from first drawer. I cleaned and checked everything but the same. I swaped the 2 paper cassetes ( I put cassete from second drawer to first and versa) and it is ok now. Any idea where the problem is?
    Re: aficio 2045
    when the problem tray is in the machine does it register the proper size of paper? if not sounds like the sensor arms on the back may be wacked
      • 36826
      Re: aficio 2045
      What is the jam number Jxxx? The xxx will tell us a where the jam actually happens and from that possibly why.
      • mikadonovan
        • May 2008
        • 2931
        Re: aficio 2045
        Pull the metal paper tray from the cassette and look at the lift plate attached to the lift shaft and see if it's not loose.
        NEVER ASSUME ANYTHING
        • DRichard
          • May 2008
          • 482
          Re: aficio 2045
          I second that. Used to see it occasionally.
          "Enjoy every sandwich."
          -- Warren Zevon
          • withnail
            • 59
            Re: aficio 2045
            Pull the paper feed unit out, there is a mylar that is hard to see when its in the device but it can tear or come unstuck.
            • mikadonovan
              • May 2008
              • 2931
              Re: aficio 2045
              Obviously not a paper feed unit. He said he swapped the paper trays and its OK now.
