mp 4001 toner issue
  • Rickh200
    • Aug 2025
    mp 4001 toner issue
    need some help please, i have a ricoh mp 4001 that after toner was replaced still saying toner depleted, how does this machine sense toner?
    • 37553
    Re: mp 4001 toner issue
    Check the toner bottle tray and the toner entry chute on the PCDU for clogs or obstructions
    • sandmanmac
      • 3983
      Agree.
      Was the bottle you replaced empty?
      If so, there's a god chance the plug from the top of the bottle is still in the toner hopper and blocking the flow from the new bottle.
      If not, then probably either a toner sensor, or toner adding problem
      • DDlan
        • Mar 2017
        • 26
        what u use toner? the counters of drum and dev.
        • Oze
          Ricoh Fanboy
          • Jul 2008
          • 1663
          I've had to replace a density sensor for this issue in the past.
          It's an awful job too.
          • withnail
            • 59
            Strip the toner hopper and check the 4 mylar paddles haven't come unstuck
